HORIZON Dump Submitted German 4K UHD
Rodney M
Post by Rodney M »
Greetings,
MKB20_v77_HORIZON_UHD_EF26.tgz
Submitted.
Regards,
Rodney M
Re: HORIZON Dump Submitted German 4K UHD
Post by Rodney M »
Unfortunately it doesn't work yet, did the dump not arrive?
Should I send it again?
best regards
keydb_helper
Post by keydb_helper »
Rodney M wrote:
Thu Nov 28, 2024 5:14 pm
Greetings,
Submitted.
Regards,
The EF26 variant of Horizon has been added to the public keydb
Public KeyDB Disc Submissions
Rodney M
Post by Rodney M »
doesn't work :(
keydb_helper
Rodney M wrote:
Tue Dec 03, 2024 1:44 pm
doesn't work :(
Hey Rodney, just to be clear, have you downloaded and setup the alternative/public key database file? I ask because the keys for your EF26 disc were added a few days ago.
The ‘keydb’ I referred to is an alternative source of disc keys, distinct from the native MakeMKV keys. If you have downloaded the latest keydb and your disc still isn’t working feel free to PM me.
Rodney M
Post by Rodney M »
Thank you very much for the quick info, I have never used the alternative/public key database file!
Do you have a link for me and how do I embed it in MKV?
Sorry for the beginner questions.
MrPenguin
Post by MrPenguin »
Rodney M wrote:
Tue Dec 03, 2024 3:13 pm
Download this ZIP file, unpack the KEYDB.cfg file inside it, copy it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restart MakeMKV.
You will need to update your KEYDB.cfg file periodically. The FindVUK.exe tool can do this:
findvuk synchronize
Rodney M
Post by Rodney M »
Thanks so much :D
