Dump Submitted - Godzilla Minus One UHD (AllTheAnime FR edition)
matheousse
MKB20_v77_GODZILLA_MINUS_ONE_343A.tgz submitted to svq@makemkv.com
The disc (from the FR Steelbook) is most likely the same as the UK and ITA Steelbooks/Deluxe Editions releasing in a few days.
Re: Dump Submitted - Godzilla Minus One UHD (AllTheAnime FR edition)
Have you tried downloading the latest KEYDB.cfg file, coping it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?matheousse wrote: Wed Nov 27, 2024 2:07 pm MKB20_v77_GODZILLA_MINUS_ONE_343A.tgz submitted to svq@makemkv.com
matheousse
I just downloaded the English (26485 entries) keydb.cfg and put it in C:\Users\XXX\.MakeMKV, unfortunately MakeMKV still couldn't dump it. (also tried the French file for good mesure, no bueno)
VikingSven
Can confirm the UK Steelbook is the same 343A versionmatheousse wrote: Wed Nov 27, 2024 2:07 pm MKB20_v77_GODZILLA_MINUS_ONE_343A.tgz submitted to svq@makemkv.com
keydb_helper
The 343A variant of Godzilla Minus One has been added to the public keydb. It should work for your disc.matheousse wrote: Wed Nov 27, 2024 2:07 pm MKB20_v77_GODZILLA_MINUS_ONE_343A.tgz submitted to svq@makemkv.com
Public KeyDB Disc Submissions
matheousse
I can see the new UHD disc in the newest keydb.cfg files (at line 58177 or thereabout), however I am still getting the The volume key is unknown for this disc - video can't be decrypted error after dragging the extracted content to C:\Users\XXX\.MakeMKV folder. Am I perhaps doing something wrong? I am also noticing that MakeMKV is downloading a new _private_data.tar archive on each attempt.keydb_helper wrote: Mon Dec 02, 2024 12:01 pm The 343A variant of Godzilla Minus One has been added to the public keydb. It should work for your disc.
For reference, here the info about my drive (I've already ripped several UHDs in the past, so I don't think something is wrong on the hardware side):
OS device name: I:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.11
Serial number: X
Firmware date: 2119-02-27 13:19
Bus encryption flags: 1E
Highest AACS version: 77
Firmware version: 3.11
The KEYDB entry also needs a VUK, i.e. a "| V |" field, which AFAICT the disk's current entry does not have. I suspect that keydb_helper has jumped the gun slightly with that comment, but am optimistic that the VUK will appear soonish nonetheless...matheousse wrote: Mon Dec 02, 2024 2:36 pm I can see the new UHD disc in the newest keydb.cfg files (at line 58177 or thereabout), however I am still getting the The volume key is unknown for this disc - video can't be decrypted error after dragging the extracted content to C:\Users\XXX\.MakeMKV folder.
Collected the UK Deluxe 4 disc edition today and can confirm that the UHD disc it a) does not open (the other Blu Ray discs work without issue) and b) generates the same "MKB20 v77 Godzilla Minus One 343A" tgz dump file.
keydb_helper
Sorry about the mix-up. Re-download the latest keydb and try again, it should be good now.matheousse wrote: Mon Dec 02, 2024 2:36 pm I can see the new UHD disc in the newest keydb.cfg files (at line 58177 or thereabout), however I am still getting the The volume key is unknown for this disc - video can't be decrypted error after dragging the extracted content to C:\Users\XXX\.MakeMKV folder. Am I perhaps doing something wrong? I am also noticing that MakeMKV is downloading a new _private_data.tar archive on each attempt.
Yep, it must've been a time zone issue...MrPenguin wrote: Mon Dec 02, 2024 2:43 pm The KEYDB entry also needs a VUK, i.e. a "| V |" field, which AFAICT the disk's current entry does not have. I suspect that keydb_helper has jumped the gun slightly with that comment, but am optimistic that the VUK will appear soonish nonetheless....
Same deal Happycy, please try with the latest keydbHappycy wrote: Mon Dec 02, 2024 9:23 pm Collected the UK Deluxe 4 disc edition today and can confirm that the UHD disc it a) does not open (the other Blu Ray discs work without issue) and b) generates the same "MKB20 v77 Godzilla Minus One 343A" tgz dump file.
matheousse
All good now, disc is being copied with the latest keydb file. Thank you!keydb_helper wrote: Tue Dec 03, 2024 4:15 am Sorry about the mix-up. Re-download the latest keydb and try again, it should be good now.
How do you download the latest keydb file?
