The Shawshank Redemption - 4k - Dump Submitted
rhummer
Submitted a dump for: MKB20_v76_The_Shawshank_Redemption_D601
MrPenguin
Re: The Shawshank Redemption - 4k - Dump Submitted
The latest KEYDB.cfg file contains several entries for this title. Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?rhummer wrote: Mon Nov 25, 2024 6:02 pm Submitted a dump for: MKB20_v76_The_Shawshank_Redemption_D601
rhummer
I use the FindUVK utility to sync up the file and it doesn't show that one for me. I grabbed the file manually as well, no dice.
rhummer
I grabbed the new file from the site manually, but I've ben using the FindVDK utility to sync the file and no luck.
Mintakax
Mintakax
I installed latest keyfile (11/30/24) and makemkv still cannot open 4K Shawshank.
rhummer
I just grabbed the new config and I was able to decode the 4k blu-ray.
Mintakax
Yep, worked for me as well. Thanks to all!
