Little Women (1994)
midnight
Little Women (1994)
Post by midnight »
New disc submitted for Little Women (1994)
MKB20_v77_Little_Women_2508.tgz
MrPenguin
Re: Little Women (1994)
Post by MrPenguin »
midnight wrote:
Wed Nov 27, 2024 1:23 pm
Have you tried downloading the latest KEYDB.cfg file, coping it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
midnight
Post by midnight »
Yes but to no avail. FWIW, I have made this part of my workflow for backing up new 4K UHD discs since new keys are added to keydb.cfg at a much faster rate than the native MakeMKV keystore.
Slightly off-topic but does anyone know how to determine the key (VUK) for a disc that I own, so it can be proactively added to keydb.cfg rather than waiting for it to be added by someone else? I'm on a Mac and don't have access to a Windows machine, if it matters.
Post by SamuriHL »
Sure. You just simply need to find an AACS 2.x processing key (PK), retrieve the media key (MK) from the MKB using the PK, use an AES-g one way hash to combine the MK and the VID, and bob's your uncle, a VUK. :lol:
If that sounds "hard" it's because it is. There are no known PK's in the wild for AACS 2.x. So....you can't.
keydb_helper
Post by keydb_helper »
The 2508 variant of Little Women has been added to the keydb.
midnight wrote:
Wed Nov 27, 2024 4:07 pm
The quickest way to get a UHD disc added to the public keydb is by sharing disc dumps produced by suitable drives. The turnaround time of this option is generally hours, not days or weeks.
(I still absolutely recommend emailing your disc dumps to the MakeMKV team)
Public KeyDB Disc Submissions
midnight
Post by midnight »
It's working now, thanks!
keydb_helper wrote:
Thu Nov 28, 2024 12:10 am
What is the preferred way to share the dump for the UHD disc to be added to the public keydb? Create a forum post and attach the tgz file?
What is considered a suitable drive? All supported LibreDrive models, or only certain ones?
Attached TGZ files will be removed, per policy.
keydb_helper
midnight wrote:
Thu Nov 28, 2024 1:08 am
No problem
As Woodstock mentioned, forum attachments are deleted these days. I recommend uploading disc dumps to a file host such as Google Drive, OneDrive, Dropbox etc and sending me the link via PM.
A 'suitable drive' currently means an LG or Asus drive. Disc dumps produced by Pioneer drives are not overly helpful at the moment. This probably won't change anytime soon.
