sorry man its too new return it if you cancwiggles wrote: Wed Nov 20, 2024 9:04 am Drive Information
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CHDL007735WL
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 76
Firmware version: ID05
LibreDrive for Pioneer drives
Damm.
I've had it for too long unfortunately. Oh well, perhaps a unlocked f/w will appear at some time in the future.
Thanks anyway.
Craig
Thanks anyway.
Craig
Flameancer
OS device name: K:
Revision: 1.01
Serial number: [redacted]
Firmware date: 2020-09-03
Drive platform: RS8E21
Firmware version: 1.01/ID05
Hello I just started ripping blu-rays again after a two year hiatus and it looks like there has been some changes with pioneer drives. I posted the details for the original drive I got for ripping UHD disk. I want to make sure that my firmware is still supported. It appears to be so judging by the date. What is the latest version I can update my drive to while still keeping Libredrive support and also is there anything I can do to help since I have the original firmware for this drive?
OS device name: K:
Revision: 1.01
bdjump2711
soo I got myself a BDR-209, I want to crossflash it to the 211 to be able to read UHD disks. However, I cannot find the firmware as I am not able to dump it and the firmware download from pioneer for the 1.53 gives me a 404. Can someone assist?bdjump2711 wrote: Mon Nov 18, 2024 11:28 am Hi!
Im fairly new to the topic and also this forum...
In the initial post of this topic, it is stated that the BDR-207 drives from pioneer would likely stay unsupported. I have such a device and would like to know if there is anything I could help with to make this drive supported for UHD BluRays (normal DVD and BluRays work like a charm tho). It is a Pioneer BDR-207EBK with very old firmware and should be Triple-Layer BD compatible, at least it's got the BdXL mark on it.
Edit: Or is there a better way to make the BDR-209 UHD ready?
OS device name: E:
Product: BD-RW BDR-209M
Revision: 1.54
Serial number: XXXXXX
Firmware date: 2020-07-21
Drive platform: RS8600
Firmware version: 1.54/ID60
Email me see belowbdjump2711 wrote: Thu Nov 21, 2024 6:49 pmsoo I got myself a BDR-209, I want to crossflash it to the 211 to be able to read UHD disks. However, I cannot find the firmware as I am not able to dump it and the firmware download from pioneer for the 1.53 gives me a 404. Can someone assist?bdjump2711 wrote: Mon Nov 18, 2024 11:28 am Hi!
Drive Information OS device name: E: Manufacturer: PIONEER Product: BD-RW BDR-209M Revision: 1.54 Serial number: XXXXXX Firmware date: 2020-07-21 Bus encryption flags: 13 LibreDrive Information Status: Enabled Drive platform: RS8600 Firmware name: PIONEER BDR-209 Firmware type: Original (unpatched) Firmware version: 1.54/ID60 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Nope, leave it alone. It is already UHD rip capable.Flameancer wrote: Thu Nov 21, 2024 4:40 pm Drive Information
OS device name: K:
Revision: 1.01
bdjump2711
Hi all,
I can recommend reaching out to billy directly via mail, everything woked nicely and I now have a uhd capable drive.
Hi everyone!
I was wondering if this drive can be flashed to suppoport UHD dics?
OS device name: G:
Product: BD-RW BDR-UD03
Revision: 1.14
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
OS device name: G:
Revision: 1.14
Product: BD-RW BDR-S13JX
Revision: 1.05
Serial number: xxxxxxxxxx
Firmware date: 2023-08-01
Highest AACS version: 81
Firmware version: ID72
Will this drive be supported in the future?
Revision: 1.05
We've spent the past 2 years wishing, but nothing has happened yetWolf359 wrote: Wed Nov 27, 2024 4:08 pm Drive Information
Pioneer firmware >= December 2022 is notorious.
Okay. Thanks.MrPenguin wrote: Wed Nov 27, 2024 5:03 pm
We've spent the past 2 years wishing, but nothing has happened yet.
Check your PM.danradff wrote: Wed Nov 27, 2024 2:05 pm Hi everyone!![]()
OS device name: G:
Revision: 1.14
Product: BD-RW BDR-XD05
Revision: 3.01
Firmware date: 2014-12-26
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
This one works, right?
Revision: 3.01
tennistmac
My Pioneer drive worked all through 2023 and into 2024. I think it stopped working in the spring, I'm assuming it is due to upgrades in MakeMKV. I believe I'm good based on the firmware date to continue ripping Blu-ray disks.
Here is my drive info:
Revision: 1.01
Serial number: BADL005116UC
Revision: 1.01
Doesn't 2014-12-26 pre-date the existence of UHD disks?Wolf359 wrote: Wed Nov 27, 2024 5:32 pm Drive Information
Revision: 3.01
