Dump Submitted - Watership Down UK
cpitchford
Post by cpitchford »
Dump file MKB20_v77_Watership_Down_UHD_DF44.tgz submitted to service queue
MrPenguin
Re: Dump Submitted - Watership Down UK
Post by MrPenguin »
cpitchford wrote: Tue Nov 26, 2024 11:18 am Dump file MKB20_v77_Watership_Down_UHD_DF44.tgz submitted to service queue
The latest KEYDB.cfg file contains this entry:
0x107F24C688D0960403DFD49C8EB24E799124A8AE = Watership Down UHD | D | 2024-10-03
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
cpitchford
Apologies!
I tried adding the line you suggested but it didn't work.
I also discovered I'd messed up downloading and installing the latest KEYDB.cfg. I found the latest KEYDB.cfg in fact contained a number of values the film:
BD_DAVID3972_WatershipDown
U5 8296597 R0 (WATERSHIP DOWN)
Watership Down UHD
WATERSHIPDOWN_BD01_DIM1 (Watership Down)
WATERSHIP_DOWN (Watership Down)
WATERSHIP_DOWN (Watership Down - Unten am Fluss)
One of these keys matched my disc and everything is now working. I'll make sure I double check when I download a new copy, rookie typo this morning!
Slimjinxs
Post by Slimjinxs »
Hi I have the UK version Its backed up but still fails to load. How do I install the the Key into the backup?
Thanks.
