Greetings,
MKB20_v77_Galaxy_Quest_D770
I submitted this and will follow up with uploading to Google Drive for KeyDB.
Regards,
Galaxy Quest Dump Submitted
Ralph P.
Re: Galaxy Quest Dump Submitted
Greetings,
This title is now part of KEYdb. I was able to successfully rip it via Makemkv. Thank you!
MrPenguin
I'm guessing MakeMKV must have computed its hashed key, because the only UHD entry in KEYDB for "Galaxy Quest" contains a unit key but no VUK.Ralph P. wrote: Mon Nov 25, 2024 8:03 pm This title is now part of KEYdb. I was able to successfully rip it via Makemkv. Thank you!
rogueranger89
I Submitted another Dump File for Galaxy Quest that has a different Code at the end.
MKB20_v77_Galaxy_Quest_E536.tgz
OneDrive Link for the files: https://1drv.ms/f/c/6191de0a61c46047/Em ... A?e=hewqsD
keydb_helper
Thanks for the disc dump. The E536 variant of Galaxy Quest has been added to the public keydbrogueranger89 wrote: Thu Nov 28, 2024 6:37 pm I Submitted another Dump File for Galaxy Quest that has a different Code at the end.
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
bluray4k
In a separate thread, Flavour found and submitted a third variant: MKB20_v77_Galaxy_Quest_60AC
agentbrowder
I've submitted another dump for Galaxy Quest for Australia:
MKB20_v77_Galaxy_Quest_631E
Also attached for keyed_helper.
keydb_helper
Thanks for the disc dump. Your disc has been added to the public keydb.agentbrowder wrote: Wed Jan 15, 2025 6:08 am I've submitted another dump for Galaxy Quest for Australia:
You were fortunate that the existing media key for Galaxy Quest matched your disc variant. Please remember that Pioneer disc dumps are generally less useful compared to LG/Asus dumps.
