The Shawshank Redemption - 4k - Dump Submitted
rhummer
Post by rhummer »
Submitted a dump for: MKB20_v76_The_Shawshank_Redemption_D601
MrPenguin
Re: The Shawshank Redemption - 4k - Dump Submitted
Post by MrPenguin »
rhummer wrote: Mon Nov 25, 2024 6:02 pm Submitted a dump for: MKB20_v76_The_Shawshank_Redemption_D601
The latest KEYDB.cfg file contains several entries for this title. Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
rhummer
Post by rhummer »
I use the FindUVK utility to sync up the file and it doesn't show that one for me. I grabbed the file manually as well, no dice.
rhummer
Post by rhummer »
I grabbed the new file from the site manually, but I've ben using the FindVDK utility to sync the file and no luck.
Mintakax
Post by Mintakax »
Same here
Mintakax
Post by Mintakax »
I installed latest keyfile (11/30/24) and makemkv still cannot open 4K Shawshank.
rhummer
Post by rhummer »
I just grabbed the new config and I was able to decode the 4k blu-ray.
Mintakax
Post by Mintakax »
Yep, worked for me as well. Thanks to all!
