Resolved - Blade Runner Final Cut 4K - Can't decrypt or backup
rotational
Post by rotational »
edit: resolved, works under Windows but not Linux for a BU40N with 1.03MK firmware.
I have previously successfully ripped a UHD (movie - Risen) with this drive, but Blade Runner Final Cut will not cooperate. This is only my second UHD disk :shock:. HD BRDs continue to work without issue. On a clean setup of MakeMKV, the first time decryption fails the latest HK file is downloaded. Once MakeMKV has the VUK I get the messages below. Trying an encrypted backup generates tons of hash check failures.
MakeMKV 1.17.8 x64 linux
Disc cleaned
Have tried drive connected via powered USB Hub
Have latest public keydb.cfg in MakeMKV's data folder
Once MakeMKV has the VUK:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:2'
Saved AACS dump file as /home/xxxxx/.MakeMKV/MKB20_v61_Blade_Runner-_The_Final_Cut_A007.tgz
MakeMKV info:
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: 1.03
Serial number: xxxxxxxxxxxxx
Highest AACS version: 61
Firmware version: 1.03
Disc Information
Label: BLADE_RUNNER_THE_FINAL_CUT
Timestamp: 2017-07-27 02:25:28
Protection: AACS2.0/C v61
Data capacity: 55.72 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Not sure what else to try besides replacing the disk. Unfortunately I don't have ready access to another suitable UHD drive or player. If ultimately it's just this BU40N (archgon) not playing nice with this release I'll just have to live with it.
MrPenguin
Re: Blade Runner Final Cut 4K - Can't decrypt or backup
Post by MrPenguin »
rotational wrote:
Sun Nov 24, 2024 6:31 pm
This doesn't look like a problem with the disc. You need to be able to enable LibreDrive.
MakeMKV info:
Revision: 1.03
Disc Information
Number of layers: 2
By rights, you should be able to decrypt using this drive. So kind of configuration issue, perhaps?
I think on Linux BU40N drives need to be flashed to the 1.00 firmware to work reliably.
rotational
dcoke22 wrote:
Mon Nov 25, 2024 6:06 am
Interesting, one of the few tests I haven't done yet is trying from a Windows box, will give that a try next.
edit: Good call. Moved the drive to a windows box and it worked first time. THANK YOU @dcoke22
Will just use Windows when I need to do UHDs as it's so infrequent. Hopefully in the future this works on linux just for convenience's sake.
I sincerely appreciate the help and suggestions from everyone!
demon
Re: Resolved - Blade Runner Final Cut 4K - Can't decrypt or backup
Post by demon »
1.03MK works consistently with my BU40N drives on Linux. You don't need 1.00 firmware.
ToonHeaded
Post by ToonHeaded »
Is this true? I have the same issue with mine since I got it. Works fine on windows but on Linux it has always had this issue.
