Nick-P
Re: Ultimate UHD Drives Flashing Guide Updated 2024
Does the Hardware Type (or Hardware Rev) e.g., SAT 8601 or SAT 8800 remain the same after flashing? Is that a reading from a chip at the hardware level?
How can I know for sure its a fake?
Does this mean it also probably wasn't really manufactured this year?
Details only via PM regarding firmwares.Nick-P wrote: Wed Nov 20, 2024 3:30 pm Does the Hardware Type (or Hardware Rev) e.g., SAT 8601 or SAT 8800 remain the same after flashing? Is that a reading from a chip at the hardware level?
My guess is that someone ordered a 212V, detached the stickers using hot air, put it on his 209 and returned that to get his money back. Check the Makemkv info on this drive and it will at least show the firmware date. Further info only via PM.
Chicknlidl
Thank you all for the hard work you put in to this. I enjoy the convenience of streaming from my NAS to my Kodi on an Odroid N2+.
I have been getting by with my LG WH14NS40.
I just picked up a Pioneer BDR-212V, which of course does not have all features from the start, but it did power up and display in makemkv.
Since I just joined up, I can't PM yet. I will try to make some useful posts to resolve that.
Hoxin
hello everyone,I have problem flashing the firmware to BP50NB40 SVC NB50
When i open SDFtool 1.3.5 and choose LG_BP50NB40_1.31_WR08_166383
MT1959 Platform shows a X
clikc START shows "The drive you have selected does not have the correct drive platform(MT1959)and cannot be flashed."
And another problem is the read speed is only 2x when i use Makemkv to buckup blu-ray discs
OS device name: E:
Manufacturer: LG
Product: BP50NB40
Revision: 1.31
Serial number: WR08 166383
Highest AACS version: 81
You are trying to flash with an incompatible firmware. Your drive is an NS40, but they didn't get the new chip until the xx50 series and later.
svc NB72?Hoxin wrote: Thu Nov 21, 2024 12:41 pm hello everyone,I have problem flashing the firmware to BP50NB40 SVC NB50
When i open SDFtool 1.3.5 and choose LG_BP50NB40_1.31_WR08_166383Code: Select all
Drive Information OS device name: E: Manufacturer: LG Product: BP50NB40 Revision: 1.31 Serial number: WR08 166383 Bus encryption flags: 1B Highest AACS version: 81
in the guide it says that wont work
they changed platforms entirely away from media tech i think
Hoxin
the lable is NB50.I brought it 2weeks ago which was manufactured in the June 2023Billycar11 wrote: Thu Nov 21, 2024 3:00 pmsvc NB72?Hoxin wrote: Thu Nov 21, 2024 12:41 pm hello everyone,I have problem flashing the firmware to BP50NB40 SVC NB50
Is that all information you get from Makemkv? It should also state "Hardware platform:" with that info. Libredrive etc.Hoxin wrote: Fri Nov 22, 2024 6:38 amthe lable is NB50.I brought it 2weeks ago which was manufactured in the June 2023Billycar11 wrote: Thu Nov 21, 2024 3:00 pmsvc NB72?Hoxin wrote: Thu Nov 21, 2024 12:41 pm hello everyone,I have problem flashing the firmware to BP50NB40 SVC NB50
would it happen to be a refurbished one?Hoxin wrote: Fri Nov 22, 2024 6:38 amthe lable is NB50.I brought it 2weeks ago which was manufactured in the June 2023Billycar11 wrote: Thu Nov 21, 2024 3:00 pmsvc NB72?Hoxin wrote: Thu Nov 21, 2024 12:41 pm hello everyone,I have problem flashing the firmware to BP50NB40 SVC NB50
cyclux
Hey guys,
I just got the following drive from Japan:
Two questions:
- To my surprise, LibreDrive does not work right away. Before I bought it, I read here in the forum it should work "out of the box". Is it not working because it is a particular, not-so-common model from Japan?
- Is it possible to flash it to the most recent FW supporting LibreDrive?
Any help would be appreciated
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: XXXX001XXXJP
Firmware version: ID69
offerbk1
Thanks. Purchased Verbatim 43888 from Amazon UK and it works OOTBMartyMcNuts wrote: Fri Nov 08, 2024 11:00 pmThe only Pioneer models you can buy direct from stores/Amazon etc that can work/can possibly be downgraded are the Pioneer BDR-212DBK, BDR-212V and the Verbatim 43888 (contains a BDR-UD04 inside).offerbk1 wrote: Mon Nov 04, 2024 3:18 pm So looking at the main post I see "PSA now most Pioneers come with new fw that prevents them from be crossflashed or downgraded do not buy one for UHD at this time"
What does it mean "Most"? Is there a
Pioneer UHD drive I can buy today from amamzon/directily from Pioneer that will allow me to RIP my collection? I prefer an external drive.
For example, BDR-XS07UHD https://usa.pioneer/collections/optical ... dr-xs07uhd
All other Pioneer models come with too new a firmware version and do not work. If you want a different model, the only chance you have of getting one is t ocheck with the sellers on this forum as they may have some available with older, compatible firmware. viewforum.php?f=20
You have a PM.cyclux wrote: Sat Nov 23, 2024 12:39 pm Hey guys,
Two questions:Code: Select all
Manufacturer: PIONEER Product: BD-RW BDR-XS07U Revision: 1.00 Serial number: XXXX001XXXJP LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8E21 Firmware version: ID69
Any help would be appreciated![]()
asmcom
No import tax when posting from Ireland.Wall.E wrote: Tue Nov 19, 2024 2:45 pmMaybe but then I don't see what else it can be.Billycar11 wrote: Tue Nov 19, 2024 2:12 pmBut the sleep bug is not that bad to recover from you really do just open close the tray
You may have a different problem
My symptom is that when a disk (not necessarily UHD) is left idle in the drive for 2 minutes, the drive stops responding.
Can't read the disk and can't open the tray either via software or its physical button. Even a reboot of the computer is not enough. I need to stop the computer and restart it.
Other than this specific case, the drive is working perfectly well and behaving as expected, like never blocked if no disk is left in the drive when unused or the drive is working.
So if it's not the sleep bug, what can I look for to investigate?![]()
I understand, but it would be at least 3 times the price. 80€ for the Asus, 260€ minimum for the cheapest Pioneer from the UK (incl. freight and VAT as the UK is not in the EU any more and it's becoming hard to escape this tax).Billycar11 wrote: Tue Nov 19, 2024 2:12 pmOr return the junky LG/Asus rebrand and get a pioneer from one of us
Asmcom
Hoxin
i have no idea,it looks pretty new.The problem is confusing me nowBillycar11 wrote: Fri Nov 22, 2024 8:19 pmwould it happen to be a refurbished one?Hoxin wrote: Fri Nov 22, 2024 6:38 amthe lable is NB50.I brought it 2weeks ago which was manufactured in the June 2023Billycar11 wrote: Thu Nov 21, 2024 3:00 pm
svc NB72?
Darkbird
Hey,
I just got a Hitachi LG BU40N on Firmware Version 1.05 which was encrypted.
I followed the guide and flashed the 1.03MK Firmware from the all you need firmware bundle as recommended in the guide, which seems to have worked fine. I have the following information in MakeMKV:
However, it seems the drive does not read any disks. I've tried DVD, CD, BluRay and 4K BluRay Disks but MakeMKV only says "No Disk Inserted".
It does recognize that I've opened/closed the drive and I can open it from within MakeMKV. Any ideas?
The drive itself does make noise as if reading the disk, however it stops and starts again every now and then.
Laufwerksinformation
OS-Gerätename: F:
Produzent: HL-DT-ST
Produkt: BD-RE BU40N
Revision: 1.03
Serienummer: redacted
Firmware-Datum: 2118-10-24 19:34
Markierungen der Bus-Verschlüsselung: 17
Firmware version: 1.03
Unrestricted read speed: YesIt does recognize that I've opened/closed the drive and I can open it from within MakeMKV. Any ideas?
