Dump Submitted - Friends Season 8 Disc 1 (The new UHD Complete Series BOX US Version)
offerbk1
Post by offerbk1 » Sat Nov 23, 2024 3:58 pm
MKB20_v77_Friends_Season_8_Disc_1_69A4.tgz (Sent to svq@makemkv.com)
Disc is playable on the Sony X800M2
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..03F to device 'IoKit:/IOBDServices/9D4CCE66'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..03F to device 'IoKit:/IOBDServices/9D4CCE66'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..07F to device 'IoKit:/IOBDServices/9D4CCE66'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..07F to device 'IoKit:/IOBDServices/9D4CCE66'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0BF to device 'IoKit:/IOBDServices/9D4CCE66'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0BF to device 'IoKit:/IOBDServices/9D4CCE66'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A30..0020..0FF to device 'IoKit:/IOBDServices/9D4CCE66'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..0020..0FF to device 'IoKit:/IOBDServices/9D4CCE66'
Error 'Scsi error - ILLEGAL REQUEST:CANNOT WRITE MEDIUM - INCOMPATIBLE FORMAT' occurred while issuing SCSI command A40..002000800 to device 'IoKit:/IOBDServices/9D4CCE66'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:/IOBDServices/9D4CCE66'
Saved AACS dump file as /Users/offerback/Library/MakeMKV/MKB20_v77_Friends_Season_8_Disc_1_69A4.tgz
MrPenguin
Re: Dump Submitted - Friends Season 8 Disc 1 (The new UHD Complete Series BOX US Version)
Post by MrPenguin » Sat Nov 23, 2024 5:57 pm
offerbk1 wrote: Sat Nov 23, 2024 3:58 pm
Your UHD drive needs to be LibreDrive compatible so that MakeMKV can disable bus encryption. What does MakeMKV say about your drive in the "information" window? (You should probably also redact your drive's serial number before posting...)
FYI if your drive is not LibreDrive compatible then your TGZ dump file is almost certainly unusable as well.
offerbk1
Post by offerbk1 » Mon Nov 25, 2024 10:56 pm
MrPenguin wrote: Sat Nov 23, 2024 5:57 pm
I have 2 identical drives (Was happy with the first one so bought a second one before we no longer have drives that are friendly OOTB). It is the Verbatim 43888 that was mentioned in many posts from Amazon UK. As I was not sure on which of the two I had the problem so I just inserted the disc to the one connected now to my Mac and tried and it does not show me the error. It is ripping "as we speak". As both drives were able to rip many discs I am not sure why it now works but I will not try to fix a problem that does not exist. thanks!
This is the info from the drive that I am using now to rip but both should be identical except for the serial.
OS device name: /dev/rdisk5
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: XXXXXXXXXX
Firmware date: 2020-06-15
Highest AACS version: 77
Drive platform: RS8A10
Firmware version: 1.14
Disc Information
Label: FRIENDS_S8_D1
Timestamp: 2024-08-07 12:47:11
Protection: AACS2.0/C v77
Data capacity: 93.22 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
