How large should dump files be?
The dump file I emailed last week (MKB20_v77_Oppenheimer_228A.tgz) is: 3.31 MB (3,476,662 bytes)
I'm not sure if that's normal or too large?
I'm still unable to rip the 4k disc.
Using MakeMKV version 1.17.7 on Windows 10, 64-bit. No internet connection issues.
Oppenheimer (2023)
Re: Oppenheimer (2023)
That sounds about right. Have you checked your private messages?datatracer wrote: ↑Tue Jul 30, 2024 3:04 amHow large should dump files be?
datatracer
I did and replied. Thanks!MrPenguin wrote: ↑Tue Jul 30, 2024 9:37 amThat sounds about right. Have you checked your private messages?datatracer wrote: ↑Tue Jul 30, 2024 3:04 amHow large should dump files be?
datatracer
My version of Oppenheimer 4K (MKB20_v77_Oppenheimer_228A.tgz) is now working!MrPenguin wrote: ↑Tue Jul 30, 2024 9:37 amThat sounds about right. Have you checked your private messages?datatracer wrote: ↑Tue Jul 30, 2024 3:04 amHow large should dump files be?
Not sure if it was MakeMKV or the updated KEYDB.cfg that did it, but it works now
Thank you!
Dump for MKB20_v77_OPPENHEIMER_CB94.tgz sent.
---EDIT---
Works now, thanks!
---EDIT---
Works now, thanks!
Dump for MKB20_v77_Oppenheimer_F7C9.tgz sent.
---EDIT---
Works now, at least with the KEYDB.cfg file, Thanks!
---EDIT---
Could you also make this TGZ dump file available here please, either as an attachment or via a download link? This would allow The Powers That KEYDB to try to add your disk to the public KEYDB.cfg file.
Here’s the dump.
- MKB20_v77_Oppenheimer_F7C9.tgz
- (159.71 KiB) Downloaded 145 times
