Dump Submitted for National Lampoon's Christmas Vacation (C24B)
Hi, first time submitting a dump so forgive me if I've done something incorrectly. I have the UK edition of National Lampoon's Christmas Vacation which has yet to have a key submitted.
Thank you.
MKB20_v76_National_Lampoon's_Christmas_Vacation_C24B.tgz
Thank you.
Re: Dump Submitted for National Lampoon's Christmas Vacation (C24B)
The latest KEYDB.cfg file contains entries for this title. Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?merlin-milo wrote: ↑Fri Nov 22, 2024 9:25 amMKB20_v76_National_Lampoon's_Christmas_Vacation_C24B.tgz
I'm having the same problem with the UK version submitted a dump file last week. With regards to the KEYDB file when ever I click on the link it doesn't work so not sure how I download this file?
The latest KEYDB.cfg file is distributed inside a ZIP file. Your browser may be objecting to this URL using HTTP instead of HTTPS.
Thank you for your help. Downloaded now and copied into the data folder, but still doesn't work
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
This sounds like your UHD drive doesn't support LibreDrive! What does MakeMKV's "info" window say? (You'll probably want to redact your drive's serial number before posting this information.)russo109 wrote: ↑Wed Nov 27, 2024 8:26 amError 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
Thanks for getting back to me. I did purchase the presetup Pioneer drive with the correct firmware etc. list from one of the MAKEmkv forum links of sellers in the UK (uhdfriendlydrives who was very helpful). I haven't updated the firmware as advised
It did use to support libredrive as I remember the information being displayed previously and was working with numerous 4k discs. This is what's is being displayed now with no mention of libredrive - not sure if its something I or Windows has done which would affect this?
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.03
Serial number:
Highest AACS version: 81
Disc Information
Label: NL_CHRISTMAS_VACATION
Timestamp: 2022-08-22 15:58:12
Protection: AACS2.0/C v76
Data capacity: 58.72 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
OS device name: E:
Revision: 1.03
Serial number:
Disc Information
Number of layers: 2
I would also expect there to be arusso109 wrote: ↑Wed Nov 27, 2024 3:33 pmDrive Information
OS device name: E:
Revision: 1.03
Serial number:
Disc Information
Number of layers: 2
Edit: Unless maybe also trying a different version of MakeMKV?
I'm guessing someone has added the key to the KEYDB file now. The libre information is displayed on opening the disc and makemkv can open and process the film now. Thanks everyone
