Top Secret!: MKB20_v77_Top_Secret!_D5BC
Airplane!: MKB20_v77_Airplane!_5662
Dumps Submitted: Top Secret! and Airplane!
chrispgriffin
MrPenguin
Re: Dumps Submitted: Top Secret! and Airplane!
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?chrispgriffin wrote: Tue Nov 19, 2024 10:19 pm Top Secret!: MKB20_v77_Top_Secret!_D5BC
chrispgriffin
That did the trick! I'll make sure to give this a try from now on before ripping, instead of spamming you guys with dump filesMrPenguin wrote: Tue Nov 19, 2024 11:11 pmHave you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?chrispgriffin wrote: Tue Nov 19, 2024 10:19 pm Top Secret!: MKB20_v77_Top_Secret!_D5BC
WEZZEBE
Could you provide me with some Stats for Airplane!
=> MediaInfo
Thx
=> MediaInfo
Thx
Toad King
I only dumped the English tracks:WEZZEBE wrote: Wed Nov 20, 2024 7:14 pm Could you provide me with some Stats for Airplane!
=> MediaInfo
Thx
General
Unique ID : 246647089767626543590317886560716137561 (0xB98E80681146EDBE2275FE8892332459)
Complete name : <REDACTED>/Airplane!_t00.mkv
Format : Matroska
Format version : Version 2
File size : 56.9 GiB
Duration : 1 h 27 min
Overall bit rate mode : Variable
Overall bit rate : 92.8 Mb/s
Frame rate : 23.976 FPS
Movie name : Airplane!
Encoded date : 2024-11-20 01:13:55 UTC
Writing application : MakeMKV v1.17.8 linux(x64-release)
Writing library : libmakemkv v1.17.8 (1.3.10/1.5.2) x86_64-pc-linux-gnu
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
HDR format : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 89.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.448
Stream size : 54.5 GiB (96%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 392 cd/m2
Original source medium : Blu-ray
Audio
ID in the original source medium : 4352 (0x1100)
Format : DTS XLL
Format/Info : Digital Theater Systems
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Bit rate : 3 739 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 2.29 GiB (4%)
Title : Surround 5.1
Language : English
Default : Yes
Forced : No
Text
ID in the original source medium : 4768 (0x12A0)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Bit rate : 44.0 kb/s
Frame rate : 0.635 FPS
Count of elements : 3328
Stream size : 27.5 MiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:Chapter 01
00:04:27.517 : en:Chapter 02
00:07:03.047 : en:Chapter 03
00:10:37.178 : en:Chapter 04
00:13:19.882 : en:Chapter 05
00:15:46.111 : en:Chapter 06
00:21:40.590 : en:Chapter 07
00:24:49.237 : en:Chapter 08
00:27:05.582 : en:Chapter 09
00:30:43.216 : en:Chapter 10
00:33:13.032 : en:Chapter 11
00:35:50.731 : en:Chapter 12
00:40:41.522 : en:Chapter 13
00:45:47.035 : en:Chapter 14
00:48:36.663 : en:Chapter 15
00:51:10.942 : en:Chapter 16
00:54:06.785 : en:Chapter 17
00:56:15.705 : en:Chapter 18
00:58:41.559 : en:Chapter 19
01:01:58.256 : en:Chapter 20
01:06:46.210 : en:Chapter 21
01:10:37.149 : en:Chapter 22
01:12:15.789 : en:Chapter 23
01:15:27.231 : en:Chapter 24
01:19:56.333 : en:Chapter 25
01:23:01.184 : en:Chapter 26
