Dumps Submitted: Top Secret! and Airplane!
chrispgriffin
Post by chrispgriffin » Tue Nov 19, 2024 10:19 pm
Top Secret!: MKB20_v77_Top_Secret!_D5BC
Airplane!: MKB20_v77_Airplane!_5662
MrPenguin
Re: Dumps Submitted: Top Secret! and Airplane!
Post by MrPenguin » Tue Nov 19, 2024 11:11 pm
chrispgriffin wrote: Tue Nov 19, 2024 10:19 pm Top Secret!: MKB20_v77_Top_Secret!_D5BC
chrispgriffin
Post by chrispgriffin » Wed Nov 20, 2024 12:30 am
MrPenguin wrote: Tue Nov 19, 2024 11:11 pm
That did the trick! I'll make sure to give this a try from now on before ripping, instead of spamming you guys with dump files :D Thanks so much!
WEZZEBE
Post by WEZZEBE » Wed Nov 20, 2024 7:14 pm
Could you provide me with some Stats for Airplane!
=> MediaInfo
Thx
Toad King
Post by Toad King » Wed Nov 20, 2024 9:14 pm
WEZZEBE wrote: Wed Nov 20, 2024 7:14 pm Could you provide me with some Stats for Airplane!
=> MediaInfo
Thx
I only dumped the English tracks:
General
Unique ID                                : 246647089767626543590317886560716137561 (0xB98E80681146EDBE2275FE8892332459)
Complete name                            : <REDACTED>/Airplane!_t00.mkv
Format version                           : Version 2
File size                                : 56.9 GiB
Duration                                 : 1 h 27 min
Overall bit rate                         : 92.8 Mb/s
Frame rate                               : 23.976 FPS
Movie name                               : Airplane!
Encoded date                             : 2024-11-20 01:13:55 UTC
Writing application                      : MakeMKV v1.17.8 linux(x64-release)
Writing library                          : libmakemkv v1.17.8 (1.3.10/1.5.2) x86_64-pc-linux-gnu
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Bit rate                                 : 89.0 Mb/s
Bits/(Pixel*Frame)                       : 0.448
Stream size                              : 54.5 GiB (96%)
Maximum Frame-Average Light Level        : 392 cd/m2
Audio
Format                                   : DTS XLL
Commercial name                          : DTS-HD Master Audio
Bit rate                                 : 3 739 kb/s
Channel layout                           : C L R Ls Rs LFE
Stream size                              : 2.29 GiB (4%)
Text
ID in the original source medium         : 4768 (0x12A0)
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Bit rate                                 : 44.0 kb/s
Frame rate                               : 0.635 FPS
Count of elements                        : 3328
Stream size                              : 27.5 MiB (0%)
Menu
00:00:00.000                             : en:Chapter 01
00:04:27.517                             : en:Chapter 02
00:07:03.047                             : en:Chapter 03
00:10:37.178                             : en:Chapter 04
00:13:19.882                             : en:Chapter 05
00:15:46.111                             : en:Chapter 06
00:21:40.590                             : en:Chapter 07
00:24:49.237                             : en:Chapter 08
00:27:05.582                             : en:Chapter 09
00:30:43.216                             : en:Chapter 10
00:33:13.032                             : en:Chapter 11
00:35:50.731                             : en:Chapter 12
00:40:41.522                             : en:Chapter 13
00:45:47.035                             : en:Chapter 14
00:48:36.663                             : en:Chapter 15
00:51:10.942                             : en:Chapter 16
00:54:06.785                             : en:Chapter 17
00:56:15.705                             : en:Chapter 18
00:58:41.559                             : en:Chapter 19
01:01:58.256                             : en:Chapter 20
01:06:46.210                             : en:Chapter 21
01:10:37.149                             : en:Chapter 22
01:12:15.789                             : en:Chapter 23
01:15:27.231                             : en:Chapter 24
01:19:56.333                             : en:Chapter 25
01:23:01.184                             : en:Chapter 26
The subtiles for the "Jive" talk are hardcoded into the video stream, the English subtitle track is a SDH one. This is different from Top Secret! where the "Swedish" subtitles are their own subtitle track.
