Dump Submitted Despicable Me 4
Submitted MKB20_v77_Despicable_Me_4_E94E
keydb_helper
Re: Dump Submitted Despicable Me 4
The E94E edition of Despicable Me 4 with disc ID 0xCBCD5826E71E9CCB83D07F2ACE796791CB58846F has been added to the public keydb file. It should work with your disc.
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
Thank you very much!
Submitted MKB_v68_Despicable_Me_4_8E5E
This is an ordinary BluRay, not a UHD disk. MakeMKV should therefore be able to decrypt it without you needing to email a dump file. Does your MakeMKV log mention anything about networking errors?
FWIW the latest KEYDB.cfg file also contains many entries for the non-UHD release of this title, so copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV might still help you.
Thank you - this helped, am able to decrypt. I wasn't getting any network errors at the time though.MrPenguin wrote: ↑Tue Nov 12, 2024 11:38 amThis is an ordinary BluRay, not a UHD disk. MakeMKV should therefore be able to decrypt it without you needing to email a dump file. Does your MakeMKV log mention anything about networking errors?
Submitted MKB20_v77_Despicable_Me_4_2778
Have you tried the latest KEYDB.cfg file? (See above...). Failing that, could you perhaps post your TGZ dump file here too please, either as an attachment or as a download link?
