Dump Submitted:MKB20_v77_The_wandering_earth_II_Disc1_CBF2(Issued in China)
BaiDuYunPan
Post by BaiDuYunPan »
MKB20_v77_The_wandering_earth_II_Disc2_FCBC
Disc from China
北京碟影传媒
Thank you so much
keydb_helper
Re: Dump Submitted:MKB20_v77_The_wandering_earth_II_Disc1_CBF2(Issued in China)
Post by keydb_helper »
BaiDuYunPan wrote: Wed Nov 13, 2024 4:31 pm MKB20_v77_The_wandering_earth_II_Disc1_CBF2
Disc from China
北京碟影传媒
Thank you so much
Both of these discs should now be supported by the public keydb
Public KeyDB Disc Submissions
BaiDuYunPan
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLJO15B3206
Bus encryption flags: 1F
Highest AACS version: 81
Firmware version: 3.10
Disc Information
Label: The wandering earth II Disc1
Timestamp: 2024-09-20 11:14:23
Protection: AACS2.0/C v77
Data capacity: 76.52 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.17.7 win(x64-release) started
Backing up disc into folder "E:/Video/backup/The wandering earth II Disc1"
Saved AACS dump file as C:\Users\BaiDuYunPan/.MakeMKV/MKB20_v77_The_wandering_earth_II_Disc1_CBF2.tgz
Backup failed
I can't seem to rip, please what is wrong, thank you very much
keydb_helper
BaiDuYunPan wrote: Wed Nov 13, 2024 11:46 pm ...
Backup failed
You need to download and configure the public key database file. The public keydb is a community driven project which MakeMKV can utilise as an alternative key source.
You can download the keydb from here: http://fvonline-db.bplaced.net/ (Direct link).
After the download has finished, you'll have a file named keydb_eng.zip. Extract/decompress this zip file and you'll get the keydb.cfg file.
If you do not unzip the downloaded zip file MakeMKV will not be able to use it. MakeMKV will not try to parse the keydb_eng.zip file. It will only read the extracted keydb.cfg
Finally, you'll need to copy the extracted keydb.cfg into the MakeMKV data directory. The default locations for each platform are:
Windows: C:\Users\<Your Username>\.MakeMKV\
Linux: /home/<Your Username>/.MakeMKV/
macOS: /Users/<Your Username>/.MakeMKV/ (I might be wrong about this one)
If you are using a custom MakeMKV data directory you will need to place the extracted keydb.cfg into your chosen directory.
For example, if MakeMKV created your disc dump file at the path F:/Bluray/MKB20_v82_Marty_Supreme_UHD_53E1.tgz you will need to place the extracted keydb.cfg file in the directory F:/Bluray/.
To account for case-sensitive filesystems, such as most Linux options and potentially macOS, you may need to rename the keydb.cfg file to KEYDB.cfg. This is not required on Windows.
MrPenguin
Post by MrPenguin »
keydb_helper wrote: Thu Nov 14, 2024 1:29 am To account for case-sensitive filesystems, such as most Linux options and potentially macOS, you may need to rename the keydb.cfg file to KEYDB.cfg. This shouldn't be required on Windows.
Rumor has it that case-sensitivity of "keydb.cfg" file name is no longer an issue. Perhaps MakeMKV is now handling this itself?
keydb_helper
MrPenguin wrote: Thu Nov 14, 2024 2:19 am Rumor has it that case-sensitivity of "keydb.cfg" file name is no longer an issue. Perhaps MakeMKV is now handling this itself?
Nice to hear, I hope that is the case. The case sensitive keydb filename might still be a factor for libaacs but that probably affects less users...
wtof_
Post by wtof_ »
The keydb.cfg works well on both two discs, thanks!
BaiDuYunPan
Backup failed
This is simply amazing, I was able to rip the disc of the Wandering Earth 2 that I bought, I am Windows, I did not change to the uppercase KEYDB, I was able to rip, thank you very much for your help as well as your team
bobtiki
Post by bobtiki »
I might have missed it, but in case anyone else hasn't clarified, the macOS default data location is:
/Users/<username>/Library/MakeMKV
I have created a shell script that you can run to quickly download and update your `keydb.cfg` file on macOS. (I'm sure it can be modified easily for Windows and Linux, but I don't have those systems to test on.) It's got some basic error checking built in, but it's not as complex as the KeyDB Helper app on Windows.
The script is hosted on GitHub here: https://gist.github.com/swizzlevixen/62 ... c129f60997 but I've also included the code below. Save it as something like `makemkv-keydb-update.sh` and run `chmod u+x makemkv-keydb-update.sh` in the terminal to make it executable. After you do that once, it should be double-clickable to launch itself in the Terminal and run the update.
#!/bin/zsh
# This script downloads the latest copy of the FindVUK Online Database,
# unzips, and moves it to the logged in user's MakeMKV data directory
# NOTE: This script is designed for use on macOS, with the default
# location for the MakeMKV data directory. If you have changed the
# location in Preferences > General, you will need to edit the line
# that moves the file, near the end of the script.
# Windows and Linux users will need to modify this to use on their systems
# Config variables
downloadUrl="http://fvonline-db.bplaced.net/fv_download.php?lang=eng"
zipName="keydb_eng.zip"
filename="keydb.cfg"
# Download
echo "Downloading latest FindVUK Online Database..."
curl -Lo "/tmp/$zipName" "$downloadUrl"
# Check for the file name (case insensitive) inside the zip
if unzip -l /tmp/$zipName | grep -qiF "$filename"; then
  # unzip file to /tmp, without any surrounding folder structure
  echo "Unzipping..."
  unzip -j /tmp/$zipName -d /tmp
else
  echo "ERROR: $filename not found inside $zipName"
  exit 1
fi
# Confirm the file exists
if [ -f "/tmp/$filename" ]; then
  # move file to MakeMKV data directory
  echo "Moving to MakeMKV data directory..."
  loggedInUser=$( echo "show State:/Users/ConsoleUser" | scutil | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
  mv /tmp/$filename /Users/$loggedInUser/Library/MakeMKV/$filename
  rm /tmp/$zipName
else
  echo "ERROR: File not found; possible error unzipping."
  exit 1
fi
echo "Done."
exit 0
Let me know if it's useful, or if you run into problems!
mikesway
Post by mikesway »
Please forgive my ignorance, but when you say save it as.... where and as what am I supposed to save it to?
Post by SamuriHL »
A text file called makemkv-keydb-update.sh. That's a shell script so you have to take the contents they provided, write them to a new file on your system, then change the permissions to make it executable using the chmod command they provided.
mikesway
Post by mikesway »
thank you. I did copy and paste into terminal, and it seemed to work. I can't verify the new disc yet because it's ripping another one at the moment. But does this look correct, this is the latter part:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 19.6M 100 19.6M 0 0 31374 0 0:10:58 0:10:58 --:--:-- 20676
zsh: number expected
zsh: command not found: #
Unzipping...
Archive: /tmp/keydb_eng.zip
inflating: /tmp/keydb.cfg
Done.
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
Post by SamuriHL »
That's not really how it's meant to be used. I don't know what system you're on (Linux, Mac, etc) and you may have to adjust this accordingly but open your terminal to whatever directory you want the new script to live. Then try something similar to this:
nano ./makemkv-keydb-update.sh
NOTE: nano may or may not be installed on your system. You will either have to install it or use whatever text editor you're familiar with.
Assuming that works and opens up a blank screen, copy and paste the entire script into that screen. Then:
control o
it'll prompt you with "File Name to write: makemkv-keydb-update.sh" so just hit enter
control x
That will exit nano
Then run 'chmod u+x makemkv-keydb-update.sh' without the single quotes
From then on you can just go to that directory and execute the script with './makemkv-keydb-update.sh' again without the single quotes.
chiefbeats
Post by chiefbeats »
keydb link is dead?
