Dump Submitted:MKB20_v77_The_wandering_earth_II_Disc1_CBF2(Issued in China)
BaiDuYunPan
#1 Post by BaiDuYunPan » Wed Nov 13, 2024 4:31 pm
MKB20_v77_The_wandering_earth_II_Disc2_FCBC
Disc from China
北京碟影传媒
Thank you so much
keydb_helper
Re: Dump Submitted:MKB20_v77_The_wandering_earth_II_Disc1_CBF2(Issued in China)
#2 Post by keydb_helper » Wed Nov 13, 2024 5:08 pm
Disc from China
北京碟影传媒
Thank you so much
Both of these discs should now be supported by the public keydb
BaiDuYunPan
#3 Post by BaiDuYunPan » Wed Nov 13, 2024 11:46 pm
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLJO15B3206
Bus encryption flags: 1F
Highest AACS version: 81
Firmware version: 3.10
Disc Information
Label: The wandering earth II Disc1
Timestamp: 2024-09-20 11:14:23
Protection: AACS2.0/C v77
Data capacity: 76.52 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.17.7 win(x64-release) started
Backing up disc into folder "E:/Video/backup/The wandering earth II Disc1"
Saved AACS dump file as C:\Users\BaiDuYunPan/.MakeMKV/MKB20_v77_The_wandering_earth_II_Disc1_CBF2.tgz
Backup failed
I can't seem to rip, please what is wrong, thank you very much
keydb_helper
#4 Post by keydb_helper » Thu Nov 14, 2024 1:29 am
Backup failed
You need to download and configure the public key database file. The public keydb is a community driven project which MakeMKV can utilise as an alternative key source.
You can download the keydb from here: http://fvonline-db.bplaced.net/ (Direct link).
After the download has finished, you'll have a file named keydb_eng.zip. Extract/decompress this zip file and you'll get the keydb.cfg file.
If you do not unzip the downloaded zip file MakeMKV will not be able to use it. MakeMKV will not try to parse the keydb_eng.zip file. It will only read the extracted keydb.cfg
Finally, you'll need to copy the extracted keydb.cfg into the MakeMKV data directory. The default locations for each platform are:
Windows: C:\Users\<Your Username>\.MakeMKV\
Linux: /home/<Your Username>/.MakeMKV/
macOS: /Users/<Your Username>/.MakeMKV/ (I might be wrong about this one)
To account for case-sensitive filesystems, such as most Linux options and potentially macOS, you may need to rename the keydb.cfg file to KEYDB.cfg. This shouldn't be required on Windows.
MrPenguin
#5 Post by MrPenguin » Thu Nov 14, 2024 2:19 am
Rumor has it that case-sensitivity of "keydb.cfg" file name is no longer an issue. Perhaps MakeMKV is now handling this itself?
keydb_helper
#6 Post by keydb_helper » Thu Nov 14, 2024 2:23 am
Nice to hear, I hope that is the case. The case sensitive keydb filename might still be a factor for libaacs but that probably affects less users...
wtof_
#7 Post by wtof_ » Thu Nov 14, 2024 2:26 pm
The keydb.cfg works well on both two discs, thanks!
BaiDuYunPan
#8 Post by BaiDuYunPan » Thu Nov 14, 2024 3:04 pm
Backup failed
This is simply amazing, I was able to rip the disc of the Wandering Earth 2 that I bought, I am Windows, I did not change to the uppercase KEYDB, I was able to rip, thank you very much for your help as well as your team
