Dump submitted - Critereon Seven Samurai 4K UHD
jiffypop
Post by jiffypop » Mon Nov 11, 2024 2:05 am
Disc Information
Label: SEVEN SAMURAI
Timestamp: 2024-09-06 13:36:44
Protection: AACS2.0/C v77
Data capacity: 89.44 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
MakeMKV v1.17.8 win(x64-release) started
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
Saved AACS dump file as C:\Users\X/.MakeMKV/MKB20_v77_SEVEN_SAMURAI_F068.tgz
Emailed to svq@makemkv.com
Gastonmt
Re: Dump submitted - Critereon Seven Samurai 4K UHD
Post by Gastonmt » Wed Nov 13, 2024 12:04 am
Ope, just submitted mine too, should have looked first haha fingers crossed this gets added soon
chronomac
Post by chronomac » Wed Nov 13, 2024 2:09 am
Just submitted mine as well.
keydb_helper
Post by keydb_helper » Fri Nov 15, 2024 1:44 am
The F068 release of Seven Samurai has been added to the public keydb
Public KeyDB Disc Submissions
KeyDB Download
EdgarQ
Post by EdgarQ » Fri Nov 15, 2024 5:11 pm
Hi, I'm new to all of this! I have the F068 release, but still getting the "Failed to open disc" error. I do have Internet access checked.
Debug logging enabled, log will be saved as C:\Users\X/MakeMKV_log.txt
Using LibreDrive mode (v01.0 id=DFE22909F92F)
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213132721
DEBUG: Code 0 at qZYX;L`>Fn{iJRFU:213131341
CrosbyCoder
Post by CrosbyCoder » Fri Nov 15, 2024 8:25 pm
Same problem here...
MakeMKV v1.17.8 linux(x64-release) started
Using LibreDrive mode (v01.0 id=E9BA8ECC61EF)
Downloading latest HK to /config/data ...
Saved AACS dump file as /config/data/MKB20_v77_SEVEN_SAMURAI_F068.tgz
MrPenguin
Post by MrPenguin » Sat Nov 16, 2024 12:26 am
CrosbyCoder wrote: Fri Nov 15, 2024 8:25 pm Same problem here...
Copy the latest KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restart MakeMKV.
EdgarQ
Post by EdgarQ » Sat Nov 16, 2024 6:59 am
MrPenguin wrote: Sat Nov 16, 2024 12:26 am
Ah, that’s what I was missing. Thank you!
CrosbyCoder
Post by CrosbyCoder » Sat Nov 16, 2024 2:38 pm
Thanks MrPenguin that worked a charm!
rhett7660
Post by rhett7660 » Mon Nov 18, 2024 4:15 am
Yes thank you... worked here also!!!!
