Can't decrypt
Dump Attached
Caligula 4k UHD 92.8 GB
Re: Caligula 4k UHD 92.8 GB
Attaching TGZ files on the forum does no good.
keydb_helper
I'm aware of the recent rule change but attaching TGZ files on the forum generally allows the disc keys to be added to the public keydb, which in turn can be used by MakeMKV.
I still recommend emailing disc dumps to the MakeMKV team for the sake of completeness.
Public KeyDB Disc Submissions
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
I did not know that when i posted
I sent the dump files for the two different Caligula 4k UHD Discs to svq@makemkv.com
CALIGULA THE ULTIMATE CUT 4 DISC COLL (2 UHD +1 BD + 1 CD) LTD NUMBERED ED
The latest KEYDB.cfg file contains several entries for "Caligula" disks. Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?Aspen5 wrote: ↑Mon Nov 11, 2024 5:45 amI did not know that when i posted
Thank you MrPenguin
"The latest KEYDB.cfg file contains several entries for "Caligula" disks. Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?"
Copying the file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV allowed me to backup BOTH Caligula UHD discs!
