Caligula 4k UHD 92.8 GB
Aspen5
Post by Aspen5 » Tue Nov 05, 2024 1:42 am
Can't decrypt
Dump Attached
Re: Caligula 4k UHD 92.8 GB
Post by Woodstock » Fri Nov 08, 2024 11:14 pm
Attaching TGZ files on the forum does no good.
keydb_helper
Post by keydb_helper » Sat Nov 09, 2024 4:01 am
Woodstock wrote: Fri Nov 08, 2024 11:14 pm Attaching TGZ files on the forum does no good.
I'm aware of the recent rule change but attaching TGZ files on the forum generally allows the disc keys to be added to the public keydb, which in turn can be used by MakeMKV.
I still recommend emailing disc dumps to the MakeMKV team for the sake of completeness.
Public KeyDB Disc Submissions
Aspen5
Post by Aspen5 » Mon Nov 11, 2024 5:45 am
I did not know that when i posted
I sent the dump files for the two different Caligula 4k UHD Discs to svq@makemkv.com
CALIGULA THE ULTIMATE CUT 4 DISC COLL (2 UHD +1 BD + 1 CD) LTD NUMBERED ED
MrPenguin
Post by MrPenguin » Mon Nov 11, 2024 3:14 pm
Aspen5 wrote: Mon Nov 11, 2024 5:45 am I did not know that when i posted
The latest KEYDB.cfg file contains several entries for "Caligula" disks. Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
Aspen5
Post by Aspen5 » Mon Nov 11, 2024 11:53 pm
Thank you MrPenguin
"The latest KEYDB.cfg file contains several entries for "Caligula" disks. Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?"
Copying the file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV allowed me to backup BOTH Caligula UHD discs!
