Dump Submitted: Caligula The Ultimate Cut 4K [Unobstructed View Release]
Fresca
Post by Fresca »
Emailed to svq@makemkv.com yesterday. Forgot to grab the dump of the second disc for the UK theatrical version.
MKB20_v77_Caligula-_The_Ultimate_Cut_7FB4.tgz
GasmaskAvenger
Re: Dump Submitted: Caligula The Ultimate Cut 4K [Unobstructed View Release]
Post by GasmaskAvenger »
Good thing I stepped in and sent the dump for the UK theatrical cut myself.
Cheers!
tbrady3742@aol.com
Post by tbrady3742@aol.com »
Just got mine and it said it couldn't open disk and then said the volume key is unknown. This is from Grindhouse. Am I missing something?
MrPenguin
Post by MrPenguin »
tbrady3742@aol.com wrote:
Sun Mar 23, 2025 9:58 pm
Yes, it sounds like you're missing a volume key. You should first email your TGZ dump file to svq@makemkv.com. However, you can also try downloading the KEYDB.cfg file, copying in into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV.
