Dear Asmcom Team,
I would like to buy a external Pioneer 4k UltraHD drive. My country of residence is Germany.
I am not quite familiar to the ripping process of BluRays, but I would like to give it a try. I have both linux and Windows systems and would like to make archives of my disks. Which external drive would you recommend?
Thank you in advance.
sláinte,
buttergolem
(Asmcom:) Pioneer UHD 4K Drives, MakeMKV Discounted Software £39.99, Worldwide Service, Excellent Service!!!
buttergolem
alninek
Re: (Asmcom:) Pioneer UHD 4K Drives From £117.32, Cheap Shipping, Worldwide Service, Excellent Service!!!
HI @Asmcom
I just payed for BDRS13EX just a few after I received your email
I sent you email as instructions
God bless
God bless
VideoVoodoo
Thank you Asmcom! I received my BDR-X13E-S drive all ok. Excited to get stuck in ripping some 4K discs!
ChrDk
Tried piggybacking on another post recommending Asmcom, but the post never got approved for some reason, so redoing it in parts here, in hopes that it gets approved:
Bought 2 (yes two) x Pioneer Premium BDR-XS07TUHD External Blu-ray Drives from Asmcom, and after a bit of confusion on my part, I got fairly quick answers from asmcom & co, and once paid, the drives arrived within 4 or 5 days (to Denmark).
The drives looks brand new, and I've tested that I can read/rip Aliens 4K (after downloading the keydb.cfg), and a normal DVD.
All in all I'm very satisfied with the service, and the product, and can therefore give my recommendation to Asmcom & co.
Now the time consuming task begins, ripping all the discs.
wsurfa
Any suggestions for an internal Pioneer just for ripping BD 4Ks with makemkv? I missed out at the beginning of the year with Asmcom so would like get something to replace my dead LG before Christmas.
I made the mistake of deleting the rips as I had everything 'safe' on my Plex server. Then I f'd up an update and lost a few 100 films..... I'm really looking forward to re-ripping everything......
asmcom
Sure, we can fix you up with a Libre-Drive Friendly Pioneer Drive.wsurfa wrote: Thu Nov 07, 2024 6:10 pm Any suggestions for an internal Pioneer just for ripping BD 4Ks with makemkv? I missed out at the beginning of the year with Asmcom so would like get something to replace my dead LG before Christmas.
Send us an email
uhdfriendlydrives@gmail.com
Hayley
wsurfa
Thanks emailed with usernameasmcom wrote: Thu Nov 07, 2024 9:09 pmSure, we can fix you up with a Libre-Drive Friendly Pioneer Drive.wsurfa wrote: Thu Nov 07, 2024 6:10 pm Any suggestions for an internal Pioneer just for ripping BD 4Ks with makemkv? I missed out at the beginning of the year with Asmcom so would like get something to replace my dead LG before Christmas.
Send us an email
Hayley![]()
Destriero
Morning Asmcom,
just bought and started using an Asus;
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number: CHDL098321WL
Firmware date: 2020-07-21
Highest AACS version: 70
Drive platform: RS8F00
Firmware version: E116/ID71
and of course it wont read any of my 4K UHD's and also a few sandard BD's like The Road.
Can you suggest a drive that will or a solution? I would have PM'd but alas a newbie
kindest regards
Des
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
kindest regards
Des
alninek
I received my Pioneer BDR-S13E-X!
I would thank @Asmcom for quick shipping and PERFECT packaging and protection!
...and also thank for unespected giift I found inside the box!!
Really thanks for perfect purchase!
God bless
God bless
asmcom
Sure, Des. Send us an email, and we can advise you of a good drive. Asmcom is having no luck with his ongoing illness, but we are still here.Destriero wrote: Sat Nov 09, 2024 9:42 am Morning Asmcom,
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
kindest regards
Des
Clare & Hayley
BBonus
I ordered a Pioneer BDR-213EBK Blu-ray optical drive with BDR-S13JX firmware 1-03 from Asmcom, it arrived very quickly. Installed in my external drive enclosure and it works perfectly with MakeMKV. Great service and communication.
Nick-P
I’m deciding between this flimsy-looking slimline drive from an eBay seller and a new, full-size internal drive from ASUS, a brand that's never let me down. My instinct says to go with ASUS, but feedback here makes me wonder if the slimline drive might actually be a better choice?
asmcom
Is this the eBay Product?Nick-P wrote: Thu Nov 14, 2024 10:12 pm I’m deciding between this flimsy-looking slimline drive from an eBay seller and a new, full-size internal drive from ASUS, a brand that's never let me down. My instinct says to go with ASUS, but feedback here makes me wonder if the slimline drive might actually be a better choice.
https://www.ebay.co.uk/itm/226110769120
you have to remember asus does not make optical drives they rebrand them from LG.Nick-P wrote: Thu Nov 14, 2024 10:12 pm I’m deciding between this flimsy-looking slimline drive from an eBay seller and a new, full-size internal drive from ASUS, a brand that's never let me down. My instinct says to go with ASUS, but feedback here makes me wonder if the slimline drive might actually be a better choice?
asmcom
Yes, as you said, Billy they are all the same; clones rebadged.Billycar11 wrote: Sat Nov 16, 2024 1:55 amyou have to remember asus does not make optical drives they rebrand them from LG.Nick-P wrote: Thu Nov 14, 2024 10:12 pm I’m deciding between this flimsy-looking slimline drive from an eBay seller and a new, full-size internal drive from ASUS, a brand that's never let me down. My instinct says to go with ASUS, but feedback here makes me wonder if the slimline drive might actually be a better choice?
Asmcom
