Plug it in and start ripping!CyberPixelPirate wrote: Sat Nov 02, 2024 10:51 pmI ordered this one. What do I do when it arrives? Or does it work as is?Coopervid wrote: Wed Oct 30, 2024 9:37 pmVerbatim 43888buttergolem wrote: Wed Oct 30, 2024 6:10 pm Good evening,
my country of residence is Germany and i need a recommendation for a reliable libre-drive friendly, external Pioneer drive.
Thank you in advance!
Have a good one!
Recommendation for best (most reliable and versatile) LibreDrive for 2024?
Re: Recommendation for best (most reliable and versatile) LibreDrive for 2024?
It works out of the box. The enclosure is power hungry. Make sure you use an USB port that delivers enough.CyberPixelPirate wrote: Sat Nov 02, 2024 10:51 pmI ordered this one. What do I do when it arrives? Or does it work as is?Coopervid wrote: Wed Oct 30, 2024 9:37 pmVerbatim 43888buttergolem wrote: Wed Oct 30, 2024 6:10 pm Good evening,
Have a good one!
travis1929
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID06
Could I get instructions for flashing this drive? Thanks in advance!
Revision: 1.02
yes see below email metravis1929 wrote: Mon Nov 04, 2024 12:22 am Drive Information
Revision: 1.02
asmcom
Subject: Alternative for Item 9 – Recommendation
Hello Jurgen,
Thank you for reaching out; as requested in your email, please find our recommendation as a follow-up to your request to enquire about Item 9 vs Item 6. Your email box is full and we have posted where you originally quoted your enquiry from "Most Reliable & Versatile Drive". Unfortunately, we do not have Item 9 in stock at the moment. However, we recommend Item 6 as an excellent alternative.
Item 6, the BDR-S13EBK, is the exact same drive used in Item 9. The key difference is that Item 9 comes with a fully plastic enclosure and no on-off switch. Item 6 features the Vantec DX2 (model NST-540S3-BK) enclosure, which is primarily made of aluminium. In our opinion, this makes Item 6 a superior option as the enclosure is sturdier and also includes an on/off switch—something Item 9 does not have.
We believe you will be pleased with the quality of Item 6.
Item 6: https://pioneer-blurayodd.eu/products/b ... /index.php
Item 6: https://www.vantecusa.com/products_detail.php?p_id=291
https://imgur.com/735VbvM
Compare with:
Item 9: https://pioneer-blurayodd.eu/products/b ... /index.php
https://imgur.com/yoM58Xi
Kind regards,
Asmcom
UHD Friendly Drives Team
go.uhdfriendlydrives.co.uk
Hello Jurgen,
Compare with:
Kind regards,
Asmcom
Benj1
Anyone got any suggestions for Denmark? Feel like i've been searching for hours (while not being sure what to look for
Full size internal or slim external?Benj1 wrote: Wed Nov 06, 2024 1:14 pm Anyone got any suggestions for Denmark? Feel like i've been searching for hours (while not being sure what to look for)
Benj1
Preferably external
Edit: I could probably 3D print an enclosure to an internal drive (assuming I can find the correct adapter), so whichever works for me!
Try to find a Verbatim 43888. It contains a Pioneer UD04 and works out of the box with UHD discs.Benj1 wrote: Thu Nov 07, 2024 8:59 am Preferably external
Edit: I could probably 3D print an enclosure to an internal drive (assuming I can find the correct adapter), so whichever works for me!![]()
Benj1
I found the one with the EAN:
0023942438885
Isn't the Pioneer drives the ones that couldn't be flashed if newer than 2022(?)
0023942438885
That's it. It will work out of the box. It has still old firmware when sold by Verbatim. That's what matters. Not the production date.Benj1 wrote: Thu Nov 07, 2024 11:52 am I found the one with the EAN:
0023942438885
Benj1
Thanks for everything, Cooper!
H3R05
Hi there, I'm also new to MakeMKV and ripping Blu-rays (including 4K) for that matter. My country of residence also is Germany.Coopervid wrote: Thu Nov 07, 2024 10:49 amTry to find a Verbatim 43888. It contains a Pioneer UD04 and works out of the box with UHD discs.Benj1 wrote: Thu Nov 07, 2024 8:59 am Preferably external
So do I understand correctly that the best or at least a good choice for getting started with a slim drive is to go for a Verbatim 43888 which contains a Pioneer UD04 that is not in production anymore, or is shipped by Verbatim with older FW that is UHD and LibreDrive friendly?
So flashing in this case is not necessary and is only done with drives to get support of 4K discs and libredrive functionality (e.g. Firmware crossflashing or downgrading?)
Thanks in advance!
Correct. This one for 102 Euros:H3R05 wrote: Sun Nov 10, 2024 12:00 pmHi there, I'm also new to MakeMKV and ripping Blu-rays (including 4K) for that matter. My country of residence also is Germany.Coopervid wrote: Thu Nov 07, 2024 10:49 amTry to find a Verbatim 43888. It contains a Pioneer UD04 and works out of the box with UHD discs.Benj1 wrote: Thu Nov 07, 2024 8:59 am Preferably external
Thanks in advance!
https://www.amazon.de/Verbatim-Blu-ray- ... 9hdGY&th=1
H3R05
Thank you Cooper! This confirmation of my initial thoughts helps me a lot. I just bought one on ebay.Coopervid wrote: Sun Nov 10, 2024 12:39 pmCorrect. This one for 102 Euros:H3R05 wrote: Sun Nov 10, 2024 12:00 pmHi there, I'm also new to MakeMKV and ripping Blu-rays (including 4K) for that matter. My country of residence also is Germany.Coopervid wrote: Thu Nov 07, 2024 10:49 am
Thanks in advance!
Cheers!
