MKB20_v77_The_Frighteners_-_Director's_Cut_D624.tgz sent by Mail today
This is the UHD Disc with the Director's Cut from the newest Collectors Edition Release (DE)
Link to files on OneDrive: https://1drv.ms/f/c/6191de0a61c46047/Eg ... 2NAjsk6mVQ
Dump Submitted: MKB20_v77_The_Frighteners_-_Director's_Cut_D624.tgz
rogueranger89
Re: Dump Submitted: MKB20_v77_The_Frighteners_-_Director's_Cut_D624.tgz
Sorry, cannot access without a MS login...rogueranger89 wrote: ↑Fri Nov 01, 2024 8:15 pmLink to files on OneDrive: https://1drv.ms/f/c/6191de0a61c46047/Eg ... 2NAjsk6mVQ
rogueranger89
https://1drv.ms/f/c/6191de0a61c46047/Eg ... Q?e=o8J3oR
the last link seemingly missed a few characters
It should be open for everyone with the link and without needing to sign in.
I sent the tgz file to the mail adress first, so someone will get it eventually.
Looks like a unit key entry was added for that title but MakeMKV can't use it, unfortunately. You'd need to use something that can use the unit key to decrypt it and then open it with MakeMKV.
keydb_helper
Thank you for providing a link to the dump file. This disc has been added to the latest public keydbrogueranger89 wrote: ↑Fri Nov 01, 2024 8:15 pmMKB20_v77_The_Frighteners_-_Director's_Cut_D624.tgz sent by Mail today
Public KeyDB Disc Submissions
- LG/Buffalo/Asus drives only (Pioneer drives are not supported)
- If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
