Dump Submitted - Deadpool and Wolverine 4K
Re: Dump Submitted - Deadpool and Wolverine 4K
#16 Post by dcoke22 » Wed Oct 23, 2024 7:51 pm
kevin040474 wrote: Wed Oct 23, 2024 7:37 pm Here is my dump file
Submit dump files via email to svq@makemkv.com.
FYI: Attached TGZ files will be removed
UHD FAQ
WAYFLIX
#17 Post by WAYFLIX » Wed Oct 23, 2024 10:24 pm
MrPenguin wrote: Tue Oct 22, 2024 9:06 pm
mikec27 wrote: Tue Oct 22, 2024 9:00 pm How did you get the keydb method to work? I tried it on two different computers and it's not working.
If your disk actually has an entry in KEYDB.cfg then these instructions are typically enough. If you are using MacOS or Linux, you will need to ensure that the file is literally named "KEYDB.cfg" and not (say) "keydb.cfg" because these operating systems have case-sensitive filesystems.
What is the full name of your TGZ dump file?
Lower case keybd.cfg works just fine on MacOS.
MrPenguin
#18 Post by MrPenguin » Wed Oct 23, 2024 10:30 pm
WAYFLIX wrote: Wed Oct 23, 2024 10:24 pm Lower case keybd.cfg works just fine on MacOS.
Hmm, that's not my understanding of how a UNIX-based operating system behaves... Can you confirm that MakeMKV is actually using the KEYDB.cfg file please, i.e. by moving the file out of the data directory, restarting MakeMKV and trying to decrypt your disk again? It occurs to me that MakeMKV might also have added your key to its hashed keys.
Mikeracing
#19 Post by Mikeracing » Thu Oct 24, 2024 8:07 pm
it the keybd didnt work for me so i sent the files to the email. hopefully gets patched soon
WAYFLIX
#20 Post by WAYFLIX » Thu Oct 24, 2024 8:35 pm
MrPenguin wrote: Wed Oct 23, 2024 10:30 pm
Yes I have tested this. Case is not sensitive.
Toad King
#21 Post by Toad King » Thu Oct 24, 2024 9:05 pm
WAYFLIX wrote: Thu Oct 24, 2024 8:35 pm
Same here on Linux. It's possible MakeMKV simply looks for either keydb.cfg or KEYDB.cfg or does more robust searching for the file.
Bguzman
#22 Post by Bguzman » Fri Oct 25, 2024 1:23 pm
Dump file submitted.
MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_CF38.tgz
(attached file removed per policy. did you send the file to svq@makemkv.com as requested?)
powrhaus
#23 Post by powrhaus » Sat Oct 26, 2024 5:28 pm
Looks like the CF38 version is working now.
charnathan
#24 Post by charnathan » Sat Oct 26, 2024 11:29 pm
E43A is working now too!
Bguzman
#25 Post by Bguzman » Mon Oct 28, 2024 12:53 am
Bguzman wrote: Fri Oct 25, 2024 1:23 pm Dump file submitted.
I just did, sorry about that.
VikingSven
#26 Post by VikingSven » Fri Nov 01, 2024 11:26 am
UK version dump file submitted, has a different ID at the end to the others in this thread
MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_FB38.tgz
bobbob
#27 Post by bobbob » Mon Nov 04, 2024 3:43 pm
timjtech wrote: Tue Oct 22, 2024 11:49 pm
mikec27 wrote: Tue Oct 22, 2024 9:33 pm
MrPenguin wrote: Tue Oct 22, 2024 9:06 pm What is the full name of your TGZ dump file?
MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_07FA
I didn't even think there might be different variations of the same movie
This is my hash as well; Canadian release possibly?
Thank you
ggiinnoo
#28 Post by ggiinnoo » Wed Nov 06, 2024 8:06 pm
A Dutch version has been submitted.
I have seen the ID before but just to be sure i have submitted it.
james_scott02
#29 Post by james_scott02 » Thu Nov 07, 2024 12:49 am
My CF38 version is not working currently. I did submit the dump.
htpc_rookie
#30 Post by htpc_rookie » Thu Nov 07, 2024 3:51 pm
MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_FB38 currently decrypting thanks to keydb.cfg
