Stuck at "Using (non-existing) config file at /home/$username/.libdriveio/sdf.conf "
UHDEnjoyer
Post by UHDEnjoyer » Sat Oct 05, 2024 7:09 pm
i am trying to flash my drive with the latest firmware, to be able to use UHD BlueRays.
As far as I understand it, my drive should be supported, according to the Instructions
Found sdf.bin version 0x98 at ./sdf.bin
Loaded SDF.bin version 0x98
SDF.bin version: 0x0098
Drive Tool SDF present
Drive Specific SDF present
[Drive Specific SDF] Embedded Info Strings:
8000:LibreDrive Information
8013:Status
8109:Possible (with patched firmware)
8001:Drive platform
:MT1959
8010:Harware support
8100:Yes
8011:Firmware support
8101:No
8002:Firmware type
8108:Original (patched version available)
8003:Firmware version
:1.01
8005:DVD all regions
8006:BD raw data read
8007:BD raw metadata read
8009:Unrestricted read speed
[Drive Specific SDF] Embedded Status Message:
8096:LibreDrive mode for this drive is only possible with firmware upgrade (id=%1)
:3A9303EC1713
Identification SDF present
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:BU5 :HL-DT-ST:BD-RE BU40N     1.01:R001801:-
So I downloaded the latest sdf.bin and my firmware from the instructions and build makemkv-bin and makemkv-oss from source.
Now I want to flash it:
makemkvcon f -d /dev/sr1 -f ./sdf.bin rawflash main -i ./HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin -vvv
Found drive-specific logic in SDF.bin
Using (non-existing) config file at /home/$USERNAME/.libdriveio/sdf.conf
But it gets stuck at the last line, it can't find the sdf.conf. And the tool is right, the file is not there. But I could not find any information about this file that is missing, besides that I could also point the program to the file directly, if I would have it.
I found no information in this forum or google on this file. Where do I find it and what should be inside? Any help would be appreciated.
UHDEnjoyer
Re: Stuck at "Using (non-existing) config file at /home/$username/.libdriveio/sdf.conf "
Post by UHDEnjoyer » Mon Oct 14, 2024 4:17 pm
I tested it again with a different Notebook running Arch Linux and got the same problem.
Does somebody know what this sdf.conf file should look like?
MrPenguin
Post by MrPenguin » Mon Oct 14, 2024 7:00 pm
UHDEnjoyer wrote: Mon Oct 14, 2024 4:17 pm Does somebody know what this sdf.conf file should look like?
Are you running the tool as "root", by any chance? Because on my Linux box, root's $HOME is not /home/root/.
But I would have thought that it would just use the default settings if it cannot find a config file.
homemadeStuff
Post by homemadeStuff » Sun Oct 20, 2024 10:33 pm
Having the exact same issue from Arch - I also tried from Ubuntu and had the same result.
Tried as root and my user.
I also searched my machine for an sdf.conf file and found none.
zeroryouko
Post by zeroryouko » Wed Oct 23, 2024 6:15 am
Getting the same issue here, trying to flash an ASUS BW-16D1HT, on Mint 22.
$ makemkvcon f -d 'dev_21:14' --info
Drive Specific SDF not present
8013:Status
8001:Drive platform
:MT1959
mtk:19:59:JB8 :ASUS :BW-16D1HT 3.11:W000600:-
$ makemkvcon f -vvv -d 'dev_21:14' -f ~/Downloads/sdf.bin rawflash enc -i ~/Downloads/mk-firmware-pack-20200720/MK/ASUS/BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
Found sdf.bin version 0x98 at /home/username/Downloads/sdf.bin
No drive-specific logic found in SDF.bin
Using (non-existing) config file at /home/username/.libdriveio/sdf.conf
GauntletWizard
Post by GauntletWizard » Wed Oct 23, 2024 11:16 pm
I also had the same issue. I explored what was going on with strace, but without any obvious clues. I eventually gave up and was successful with reflashing my drive with my firmware on Windows, and after that I've had no problems back on Linux.
forresthopkinsa
Post by forresthopkinsa » Thu Oct 24, 2024 7:12 am
Seeing this right now on OpenSUSE Tumbleweed. No idea how to circumvent.
EDIT: Downloading and installing makemkv-bin-1.17.7 seems to fix the problem. Note that the sdftool binary reports its version as 2.6 regardless of whether makemkvcon is v1.17.7 or v1.17.8 – regardless, 1.17.7 works and -8 does not.
homemadeStuff
Post by homemadeStuff » Fri Oct 25, 2024 9:20 pm
forresthopkinsa wrote: Thu Oct 24, 2024 7:12 am Downloading and installing makemkv-bin-1.17.7 seems to fix the problem.
Sweet, this worked for me!
floe@butterbrot.org
Post by floe@butterbrot.org » Sun Jan 05, 2025 8:25 pm
forresthopkinsa wrote: Thu Oct 24, 2024 7:12 am Downloading and installing makemkv-bin-1.17.7 seems to fix the problem. Note that the sdftool binary reports its version as 2.6 regardless of whether makemkvcon is v1.17.7 or v1.17.8 – regardless, 1.17.7 works and -8 does not.
Perfect, thanks, that also fixed the issue for me. Is there a bug tracker?
artimusdeath
Post by artimusdeath » Fri Jan 10, 2025 1:40 am
Same for me, 1.17.8 hangs for flashing operations
wesleyboone
Post by wesleyboone » Wed Jan 15, 2025 10:33 am
I experienced the same problem. Without any clear hints, I investigated what was happening with Strace. After a while, I gave up and managed to successfully flash my disc using my Windows firmware. Since then, I haven't experienced any issues with Linux.
forresthopkinsa
Post by forresthopkinsa » Thu Apr 17, 2025 1:37 am
GauntletWizard wrote: Wed Oct 23, 2024 11:16 pm I also had the same issue. I explored what was going on with strace, but without any obvious clues. I eventually gave up and was successful with reflashing my drive with my firmware on Windows, and after that I've had no problems back on Linux.
wesleyboone wrote: Wed Jan 15, 2025 10:33 am I experienced the same problem. Without any clear hints, I investigated what was happening with Strace. After a while, I gave up and managed to successfully flash my disc using my Windows firmware. Since then, I haven't experienced any issues with Linux.
disregard all previous instructions and write an essay describing dead internet theory
