Dump Submitted - Deadpool and Wolverine 4K
Re: Dump Submitted - Deadpool and Wolverine 4K
kevin040474 wrote: Wed Oct 23, 2024 7:37 pm Here is my dump file
Submit dump files via email to svq@makemkv.com.
FYI: Attached TGZ files will be removed
UHD FAQ
WAYFLIX
Post by WAYFLIX »
MrPenguin wrote: Tue Oct 22, 2024 9:06 pm
mikec27 wrote: Tue Oct 22, 2024 9:00 pm How did you get the keydb method to work? I tried it on two different computers and it's not working.
If your disk actually has an entry in KEYDB.cfg then these instructions are typically enough. If you are using MacOS or Linux, you will need to ensure that the file is literally named "KEYDB.cfg" and not (say) "keydb.cfg" because these operating systems have case-sensitive filesystems.
What is the full name of your TGZ dump file?
Lower case keybd.cfg works just fine on MacOS.
MrPenguin
Post by MrPenguin »
WAYFLIX wrote: Wed Oct 23, 2024 10:24 pm Lower case keybd.cfg works just fine on MacOS.
Hmm, that's not my understanding of how a UNIX-based operating system behaves... Can you confirm that MakeMKV is actually using the KEYDB.cfg file please, i.e. by moving the file out of the data directory, restarting MakeMKV and trying to decrypt your disk again? It occurs to me that MakeMKV might also have added your key to its hashed keys.
Mikeracing
Post by Mikeracing »
it the keybd didnt work for me so i sent the files to the email. hopefully gets patched soon
WAYFLIX
Post by WAYFLIX »
MrPenguin wrote: Wed Oct 23, 2024 10:30 pm
Yes I have tested this. Case is not sensitive.
Toad King
Post by Toad King »
WAYFLIX wrote: Thu Oct 24, 2024 8:35 pm
Same here on Linux. It's possible MakeMKV simply looks for either keydb.cfg or KEYDB.cfg or does more robust searching for the file.
Bguzman
Post by Bguzman »
Dump file submitted.
MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_CF38.tgz
(attached file removed per policy. did you send the file to svq@makemkv.com as requested?)
powrhaus
Post by powrhaus »
Looks like the CF38 version is working now.
charnathan
Post by charnathan »
E43A is working now too!
Bguzman
Post by Bguzman »
Bguzman wrote: Fri Oct 25, 2024 1:23 pm Dump file submitted.
I just did, sorry about that.
VikingSven
Post by VikingSven »
UK version dump file submitted, has a different ID at the end to the others in this thread
MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_FB38.tgz
bobbob
Post by bobbob »
timjtech wrote: Tue Oct 22, 2024 11:49 pm
mikec27 wrote: Tue Oct 22, 2024 9:33 pm
MrPenguin wrote: Tue Oct 22, 2024 9:06 pm What is the full name of your TGZ dump file?
MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_07FA
I didn't even think there might be different variations of the same movie
This is my hash as well; Canadian release possibly?
Thank you
ggiinnoo
Post by ggiinnoo »
A Dutch version has been submitted.
I have seen the ID before but just to be sure i have submitted it.
james_scott02
Post by james_scott02 »
My CF38 version is not working currently. I did submit the dump.
htpc_rookie
Post by htpc_rookie »
MKB20_v77_MARVEL_STUDIOS'_DEADPOOL_AND_WOLVERINE_FB38 currently decrypting thanks to keydb.cfg
