Dump Submitted Longlegs UHD
bsather
#1 Post by bsather » Thu Sep 19, 2024 2:40 pm
MKB20_v77_UHD_LNGL_5A36
MrPenguin
Re: Dump Submitted Longlegs UHD
#2 Post by MrPenguin » Thu Sep 19, 2024 3:02 pm
bsather wrote: Thu Sep 19, 2024 2:40 pm MKB20_v77_UHD_LNGL_5A36
The latest KEYDB.cfg file contains this entry:
0xE7CBD3E945FA4C761B95A1034BF8F2A4C5935806 = UHD_LNGL (Longlegs) | D | 2024-06-29
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
bsather
#3 Post by bsather » Thu Sep 19, 2024 5:50 pm
Yes. Thank you!
astrocoolin
#4 Post by astrocoolin » Wed Sep 25, 2024 10:35 pm
submitted
MKB20_v77_Longlegs_2294
keydb_helper
#5 Post by keydb_helper » Fri Sep 27, 2024 3:29 pm
astrocoolin wrote: Wed Sep 25, 2024 10:35 pm submitted
The 2294 release of Longlegs with the disc ID 0xD30AD1993F62659F39FE355405295DE1C0EDFC5D has been added to the public keydb. It should work with your disc.
Public KeyDB Disc Submissions
KeyDB Download
Ballesteros
#6 Post by Ballesteros » Tue Oct 22, 2024 5:24 pm
Submitted MKB20_v77_Longlegs_8AD0.tgz for UK UHD release.
sandersoni
#7 Post by sandersoni » Wed Oct 23, 2024 7:35 pm
Ballesteros wrote: Tue Oct 22, 2024 5:24 pm Submitted MKB20_v77_Longlegs_8AD0.tgz for UK UHD release.
Thank you!
sandersoni
#8 Post by sandersoni » Sat Oct 26, 2024 8:57 am
MrPenguin wrote: Thu Sep 19, 2024 3:02 pm
In since this morning.
lexwalk
#9 Post by lexwalk » Mon Feb 03, 2025 8:34 pm
Submitted MKB20_v77_Longlegs_B818.tgz
I just emailed is that log dump to svq, did I need to do anything else?
MrPenguin
#10 Post by MrPenguin » Tue Feb 04, 2025 12:10 am
lexwalk wrote: Mon Feb 03, 2025 8:34 pm Submitted MKB20_v77_Longlegs_B818.tgz
No, but it would be "kind" to KEYDB if you could also make your TGZ dump available somehow please, e.g. attach it to a reply here or post a link to (say) Google Drive or OneDrive?
Have you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes TGZ dump files) and restarting MakeMKV?
lexwalk
#11 Post by lexwalk » Tue Feb 04, 2025 8:08 pm
MrPenguin wrote: Tue Feb 04, 2025 12:10 am
Downloaded that file and placed it in the MakeMKV data folder (unzipped and zipped) and when I restarted MakeMKV and tried to re-open the Longlegs 4K disc it still produced the dump file attached here. However there's no indication MakeMKV tried to consume the new keydb.cfg upon opening (no text saying it's doing so in the log when launching or opening the disc). Do I need to rename it? It's sitting in the same place where it writes dump files. How will I know if it's been properly consumed?
MakeMKV v1.17.9 win(x64-release) started
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
Saved AACS dump file as C:\Users\------/.MakeMKV/MKB20_v77_Longlegs_B818.tgz
Here is the link for the dump file...
https://drive.google.com/file/d/15y-MWY ... sp=sharing
keydb_helper
#12 Post by keydb_helper » Tue Feb 04, 2025 9:44 pm
lexwalk wrote: Tue Feb 04, 2025 8:08 pm Downloaded that file and placed it in the MakeMKV data folder (unzipped and zipped) and when I restarted MakeMKV and tried to re-open the Longlegs 4K disc it still produced the dump file attached here. However there's no indication MakeMKV tried to consume the new keydb.cfg upon opening (no text saying it's doing so in the log when launching or opening the disc). Do I need to rename it? It's sitting in the same place where it writes dump files. How will I know if it's been properly consumed?
I might be mistaken but I don't believe MakeMKV provides any indication in its logs when it is using the public keydb. In your case we know that MakeMKV couldn't utilise the keydb because there was no key for your disc in the public keydb at that time.
If you have the extracted "keydb.cfg" file in the same directory where your dump files are created then you have followed the correct process.
To check if your disc is supported, you can calculate the SHA-1 hash of the "Unit_Key_RO.inf" file in your discs "AACS" folder. If there is a matching entry in the keydb.cfg file you have a good chance of being able to decrypt your disc.
lexwalk wrote: Tue Feb 04, 2025 8:08 pm Here is the link for the dump file...
Thanks for providing the dump file. Your variant of Longlegs has now been added to the public keydb. So download the latest keydb file and replace your local copy or use SamuriHL's keydb utility for Windows (Link)
KeyDB Download
lexwalk
#13 Post by lexwalk » Thu Feb 06, 2025 10:34 pm
keydb_helper wrote: Tue Feb 04, 2025 9:44 pm
Just providing an update. Thank you all, with the updated keydb.cfg from today in my data folder, my disc was now able to be read. Thank you all for your help, this was an educational experience and I'll make sure to follow these steps next time I encounter this.
