Submitted Twisters
Digicipher
Submitted Twisters
Post by Digicipher »
Submitted Twisters MKB20_v77_Twisters_2AB6.tgz
yesterda an word on this yet?
Re: Submitted Twisters
Well, there's a bunch of threads about Twisters (2024). It is hard to keep track of it when people don't keep everything in the same thread.
Twisters UK 4k dump
submitted dump - Twisters 4K
Dump Submitted - Twisters 4K UHD
Dump Submitted MKB20_v77_Twisters_D2E2
str8_whiskey
Post by str8_whiskey »
Where do I submit a dump & can I submit multiple dumps in one email?
svq@makemkv.com
How many TGZ files you can submit depends on your email program and service.
MrPenguin
Post by MrPenguin »
Digicipher wrote:
Wed Oct 23, 2024 3:26 pm
Have you tried with KEYDB.cfg?
Digicipher
My understanding is that key works for a differrent Key!?? Not for 2AB6 key. Also my folder has "keys_hashed.txt" not "KEYDB.cfg" where do you get KEYDB.cfg and what folder do you add it to?
Digicipher
I tried KEYDB.cfg and it worked Unless they updated the keys file Twisters_2AB6
!! Anyway thanks from the push to give it a shot as it decrypted the file right away. I just copied the KEYDB.cfg in the .MakeMKV file under users folder and it worked so if you have Twisters_2AB6 just add the KEYDB.cfg file and you are good to go.
