submitted dump - Twisters 4K
Geneo
Post by Geneo » Tue Oct 22, 2024 9:10 pm
Here is my dump file. Using the latest version of MKV 1.17.8
Geneo
Re: submitted dump - Twisters 4K
Post by Geneo » Tue Oct 22, 2024 9:13 pm
Forgot the file
MKB20_v77_Twisters_2AB6.tgz
Geneo
Post by Geneo » Tue Oct 22, 2024 9:16 pm
Forgot the file add the file
Post by MartyMcNuts » Tue Oct 22, 2024 9:29 pm
Geneo wrote: Tue Oct 22, 2024 9:16 pm Forgot the file add the file
DO NOT attach the dump file here! We only need the file name in the threads. You must email the dump file to svq@makemkv.com so a key can be added to the HK download file.
Post by SamuriHL » Tue Oct 22, 2024 9:58 pm
6DE4EE3A32CD258C63B1AC5B45814317A712962A
That's your disc ID and it already has an entry in the keydb. So you can use that until support is added.
GUNNER
Post by GUNNER » Tue Oct 22, 2024 10:04 pm
Dump Submitted.
SeaLight
Post by SeaLight » Fri Oct 25, 2024 1:56 am
I just submitted one as well.
Jerkwater
Post by Jerkwater » Fri Oct 25, 2024 5:39 am
Manually downloading the current keydb.cfg file and putting it in the C:\Users\<username>\.MakeMKV folder just worked for me for this disc (I'm using Windows 10).
I kept trying to rip it unsuccessfully for the past 2 days. I have the "Enable Internet access" box checked in Preferences/General, so I assumed the failures were caused by the key not being available. Maybe my ISP or something else has started to interfere with my online updates.
indyjoe1977
Post by indyjoe1977 » Fri Oct 25, 2024 2:17 pm
Where do you find that file at?
MrPenguin
Post by MrPenguin » Fri Oct 25, 2024 2:25 pm
indyjoe1977 wrote: Fri Oct 25, 2024 2:17 pm Where do you find that file at?
Right here.
MrPenguin
Post by MrPenguin » Fri Oct 25, 2024 2:29 pm
Jerkwater wrote: Fri Oct 25, 2024 5:39 am I kept trying to rip it unsuccessfully for the past 2 days. I have the "Enable Internet access" box checked in Preferences/General, so I assumed the failures were caused by the key not being available. Maybe my ISP or something else has started to interfere with my online updates.
KEYDB is an optional alternative database of keys that MakeMKV can use, should it be available. MakeMKV has its own "hashed keys" database which it downloads automatically over the Internet, and is more convenient to use but also takes an unknown / unknowable length of time to acquire new keys.
RoscoeK
Post by RoscoeK » Sat Oct 26, 2024 5:32 am
Dump submitted.
MKB20_v77_Twisters_4E84
This did not work in the latest KEYDB.CFG either. Thanks.
RoscoeK
Post by RoscoeK » Sat Oct 26, 2024 12:26 pm
Now working, thank you.
Pino72
Post by Pino72 » Thu Nov 21, 2024 5:11 pm
Twisters does not decode yet...also tried with keydb.cfg Englisch and German but no success. Send the dump to the email address.
MKB20_v77_TWISTERS_19A6.tgz
Pino72
Post by Pino72 » Wed Nov 27, 2024 10:03 am
Anybody had success in ripping this version?
Still not working for me....submitted dump some days ago.
