Got an LG drive but where do I get the firmware to flash it? It sounds like I need version 1.0
Product: BD-RE BU40N
Revision: 1.02
Serial number: MO9N1U93301
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Unrestricted read speed: Possible (with patched firmware
LG BD-RE BU40N Looking for firmware
Re: LG BD-RE BU40N Looking for firmware
viewtopic.php?p=94848#p94848Reveille wrote: ↑Tue Oct 22, 2024 2:13 amGot an LG drive but where do I get the firmware to flash it? It sounds like I need version 1.0
Revision: 1.02
When trying to flash the drive I am getting this error
Command produced error code 0x82052603
What firmware are you using and are you using enc?
Firmware is from link above zip file downgrade enabled firmware v.2. I am trying to flash DE_LG BU40N_1.00.bin with the SDFtool Flasher (v1.3.5). I am not familiar with what enc is?
See guide below your doing it wrong
Thank you your links worked great! Everything working perfectly.
