External drive advice...
brecht
Post by brecht » Sun Oct 20, 2024 11:21 pm
All the external pioneer drives i've looked at say "for windows" or "for windows and mac os" on the box, so now im not sure which one i should get. Do they work with linux? Is there any specific drive i should get for 4k bluray ripping?
MrPenguin
Re: External drive advice...
Post by MrPenguin » Mon Oct 21, 2024 11:25 am
brecht wrote: Sun Oct 20, 2024 11:21 pm All the external pioneer drives i've looked at say "for windows" or "for windows and mac os" on the box, so now im not sure which one i should get. Do they work with linux? Is there any specific drive i should get for 4k bluray ripping?
Yes, USB drives are just "mass storage devices" and so work fine with Linux. MakeMKV requires that the drive's /dev/srN device also has a corresponding /dev/sgM device, but that's just a matter of the kernel supporting "SCSI generic".
As for supporting UHD, you will need to buy a Pioneer drive whose firmware is dated 2022-11 or earlier, which is becoming increasingly difficult as existing stocks run out. Drives manufactured more recently have updated their firmware both to block MakeMKV's LibreDrive and to prevent downgrading.
Post by Coopervid » Mon Oct 21, 2024 11:53 am
Depending on your country of residence you might find a Verbatim 43888 which contains a Pioneer UD04 that works out-of-the-box.
flojo
Post by flojo » Mon Oct 21, 2024 1:06 pm
MrPenguin wrote: Mon Oct 21, 2024 11:25 am becoming increasingly difficult as existing stocks run out.
Overly niche I'd say. It's easier to find a working laserdisc player :-/
MrPenguin
Post by MrPenguin » Mon Oct 21, 2024 1:36 pm
flojo wrote: Mon Oct 21, 2024 1:06 pm Overly niche I'd say. It's easier to find a working laserdisc player :-/
It depends who you ask. I believe asmcom still has some - for now at least.
