Now which excuse is your next after the PSU and your family? I would have hundreds unread PMs. And there is no Bill and Ted but Billycar11 and MartyMcNuts. So pay your $25 to one of them to get your drive upgraded. I just don't like guys who post and don't show anymore for a long time. That's it.Upload8 wrote: Tue Oct 15, 2024 3:05 pm If I would get an Notification eMail, I would agree. But I don't. And I'm not able to visit the Forum everyday. I'm only able to keep up with nerdy PC things when my family is away and I have no work to do. Beside the fact, that I don't get what you mean by paying Bill & Ted some money? Is this some kind of inside joke? I'm not that good in the english language to get it. And why are you keep deleting the PMs. I'm lost.
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
MrPenguin
Go to "User Control Panel" / "Board preferences" / "Edit notification options" for your MakeMKV forum's profile. You can ask the forum to send you an email for certain events.Upload8 wrote: Tue Oct 15, 2024 3:05 pm If I would get an Notification eMail, I would agree. But I don't.
OhItsStefan
I recently got the Verbatim Slimline 4k UHD drive (BD-RW BDR-UD03) as well. I tested some stuff and most people said it worked straight out of the box, the only UHD Blu-ray I have to test didn't work. It refuses to read it and says there's no disc inserted. I came upon this thread and hope to flash it back so it is able to rip UHD content.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: .................
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
The task to flash back the firmware seems daunting, as I have no experience with it and there's a potential to brick the drive. It seems instructions will be provided in PM, if so, please make it as foolproof as possible if it's not too much to ask. Thanks in advance!
OS device name: E:
Revision: 1.14
UHDFanBC
Add my voice to the chorus of those hoping to tweak my UD03 to rip UHD discs in MakeMKV.
Revision: 1.10
Serial number: << Redacted >>
Firmware date: 2017-04-18
Highest AACS version: 76
Firmware version: 1.10
Thanks in advance.
Revision: 1.10
Thanks in advance.
Pm coming.OhItsStefan wrote: Thu Oct 17, 2024 1:17 pm I recently got the Verbatim Slimline 4k UHD drive (BD-RW BDR-UD03) as well. I tested some stuff and most people said it worked straight out of the box, the only UHD Blu-ray I have to test didn't work. It refuses to read it and says there's no disc inserted. I came upon this thread and hope to flash it back so it is able to rip UHD content.
OS device name: E:
Revision: 1.14
Pm to be read.UHDFanBC wrote: Thu Oct 17, 2024 8:49 pm Add my voice to the chorus of those hoping to tweak my UD03 to rip UHD discs in MakeMKV.
Revision: 1.10
Thanks in advance.
UHDFanBC
Read and executed. Worked without any drama or errors. Drive now identifies as a UD04, and MakeMKV is chewing on a UHD disc on my M2 MacBook Air as I type this. Thanks again.
For those interested, I used a Windows 10 VM running under VMware Fusion on a 2014-vintage Intel Mac mini to flash the drive. Closest thing to a Windows box I have, and it performed admirably.
OhItsStefan
This was over in a flash (pun definitely intended), thank you! Like the other user said, my drive is also currently chipping away at a UHD Blu-ray without any issues.Coopervid wrote: Thu Oct 17, 2024 10:56 pmPm coming.OhItsStefan wrote: Thu Oct 17, 2024 1:17 pm I recently got the Verbatim Slimline 4k UHD drive (BD-RW BDR-UD03) as well. I tested some stuff and most people said it worked straight out of the box, the only UHD Blu-ray I have to test didn't work. It refuses to read it and says there's no disc inserted. I came upon this thread and hope to flash it back so it is able to rip UHD content.
OS device name: E:
Revision: 1.14
For anyone being as hesitant as I was regarding flashing the firmware, don't be, it's genuinely a case of clicking 3 buttons and waiting. Just make sure to thoroughly read the provided tutorial BEFORE even attempting to open the flashing software.
mike_ranger
Hello
I have the same problem.
The drive cannot read UHD discs.
I would be very happy about a PM.
Thanks, Mikel
Thanks, Mikel
araemo
I have one of these that has an older firmware, so I think it is possible to crossflash?
OS device name: H:
Revision: 1.14
Serial number: ...
Highest AACS version: 77
Unrestricted read speed: Yes-
Post your Makemkv info.mike_ranger wrote: Fri Oct 18, 2024 12:47 pm Hello
Thanks, Mikel
PM is coming.araemo wrote: Fri Oct 18, 2024 5:50 pm I have one of these that has an older firmware, so I think it is possible to crossflash?
Drive Information OS device name: H: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: ... Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 77 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
araemo
Thank you very much. Worked perfectly.Coopervid wrote: Fri Oct 18, 2024 8:46 pmPM is coming.araemo wrote: Fri Oct 18, 2024 5:50 pm I have one of these that has an older firmware, so I think it is possible to crossflash?
FidgetyZookeeper
Mind if I also request the Pioneer firmware fix for UHD disc reading? (Sorry I know there have been a lot of these)
OS device name: /dev/sr0
Current profile: DVD-ROM
Revision: 1.14
Serial number: <>
PM sent.FidgetyZookeeper wrote: Sat Oct 19, 2024 12:40 am Mind if I also request the Pioneer firmware fix for UHD disc reading? (Sorry I know there have been a lot of these)Code: Select all
Drive Information OS device name: /dev/sr0 Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: <> Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
