Dump submitted: I Walked With a Zombie/The Seventh Victim UK Criterion
mwebb
Post by mwebb » Mon Oct 14, 2024 9:37 pm
Dump file: MKB20_v77_I_WALKED_WITH_A_ZOMBIE_THE_SEVENTH_VICTIM_ACD0.tgz
MrPenguin
Re: Dump submitted: I Walked With a Zombie/The Seventh Victim UK Criterion
Post by MrPenguin » Mon Oct 14, 2024 10:43 pm
mwebb wrote: Mon Oct 14, 2024 9:37 pm Dump file: MKB20_v77_I_WALKED_WITH_A_ZOMBIE_THE_SEVENTH_VICTIM_ACD0.tgz
The latest KEYDB.cfg file contains this entry:
0x81088AB2250096054522C3859F20CAF52A20E5AE = I WALKED WITH A ZOMBIE UHD (I WALKED WITH A ZOMBIE / THE SEVENTH VICTIM) | D | 2024-08-02
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
mwebb
Post by mwebb » Tue Oct 15, 2024 12:39 pm
I appreciate the suggestion, but I after downloading a copy over the 15th October keydb file I still get volume key is unknown. ...though that being said I've never ever been able to get makemkv to read from a keydb.cfg file, ever never.
MrPenguin
Post by MrPenguin » Tue Oct 15, 2024 1:31 pm
mwebb wrote: Tue Oct 15, 2024 12:39 pm ...though that being said I've never ever been able to get makemkv to read from a keydb.cfg file, ever never.
The KEYDB.cfg file would need to contain an entry for your disk in order to help, of course. But you only need to copy the file into MakeMKV's data directory and restart MakeMKV. (For MacOS and Linux, you also need to ensure that it's literally named KEYDB.cfg, and not (say) keydb.cfg, because these operating systems have case-sensitive filesystems.)
The data directory is displayed in MakeMKV's View/Preferences/General tab, and is where MakeMKV also writes its TGZ dump files.
keydb_helper
Post by keydb_helper » Wed Oct 16, 2024 5:22 am
The ACD0 release of I Walked With a Zombie/The Seventh Victim with disc ID 0x03728249E9D95B3D0870427C4B8DE26633AC170F has been added to the public keydb.
It should work with your disc.
Public KeyDB Disc Submissions
mwebb
Post by mwebb » Wed Oct 16, 2024 7:41 am
New keys auto downloaded this morning and confirmed as now working. Excellent job.
