Dump submitted - MKB20_v76_Mad_Max_2-_The_Road_Warrior_25B7
Mitsu
#1 Post by Mitsu » Tue Oct 15, 2024 6:10 am
Hello, i already submit this dumb by mail to svq@makemkv.com a few days ago.
Thanks for your help :)
MrPenguin
Re: Dump submitted - MKB20_v76_Mad_Max_2-_The_Road_Warrior_25B7
#2 Post by MrPenguin » Tue Oct 15, 2024 1:51 pm
The latest KEYDB.cfg file contains these entries:
0x016FC73B59210BF44FA9BDD552FBBB902268925E = MAD_MAX_2_THE_ROAD_WARRIOR (Mad Max 2: The Road Warrior) | D | 2021-09-29
0x4BA628458F5145E506C250A50E71405EC555C613 = MAD_MAX_2_THE_ROAD_WARRIOR [Mad Max 2: The Road Warrior 4K Ultra HD] | D | 2021-12-08
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
Mitsu
#3 Post by Mitsu » Wed Oct 16, 2024 6:57 am
Thanks, it works.
However, I had tried to put the KEYDB.cfg file in the same location before my request, but I could not copy the BD.
Perhaps it was necessary to remove the first part of text from KEYDB.cfg or limit it to the only title likely to correspond?
Thanks again !
MrPenguin
#4 Post by MrPenguin » Wed Oct 16, 2024 2:12 pm
Thanks, it works.
You should install the entire KEYDB.cfg file into MakeMKV's data directory. The lines I posted above are meaningless by themselves because they deliberately contain no keys.
KEYDB.cfg is updated regularly, so it's always worth checking for new keys. The best way to update it is to execute "findvuk synchronize" rather than re-downloading the entire file each time.
