Twisters UK 4k dump
htpc_rookie
Twisters UK 4k dump
MKB20_v77_Twisters_8A08.tgz submitted
Re: Twisters UK 4k dump
The latest KEYDB.cfg file contains this entry:
0x3E8B703B53A1D1823FAC0B8B10FCF8F8BDB89F22 = TWISTERS (Twisters) | D | 2024-08-12-
htpc_rookie
Thanks for that. I'm not in a great hurry to watch these films so I'll wait a few days and try again. I will download the file though so that I'm ready to deploy and give it a go.
Ballesteros
Thanks for the heads up - the keydb update worked for me with the UK 4K "MKB20_v77_Twisters_8A08" disc.MrPenguin wrote: Mon Oct 14, 2024 1:52 pm The latest KEYDB.cfg file contains this entry:Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?Code: Select all
MKB20_v77_TWISTERS_UPK75_2AB6
submitted as well
submitted as well
indyjoe1977
Sweet. I just snagged this one last night, so hopefully that key is available soon. Thank you for submitting the 2AB6 disc.
I'm sorry, how do I use this key file?MrPenguin wrote: Mon Oct 14, 2024 1:52 pmThe latest KEYDB.cfg file contains this entry:Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?Code: Select all
See above?MrPenguin wrote: Mon Oct 14, 2024 1:52 pm Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
