Menu problem with Blu-Ray 4K on VLC
markofwolves
Post by markofwolves »
Hello. I have problems with 4k Blu-Rray menu with VLC. The image appears but not with the buttons. I use Java version 8, update 421 build 1.8.0_421_b09. How can I solve it? Thanks.
Toad King
Re: Menu problem with Blu-Ray 4K on VLC
Post by Toad King »
It could depend on the video output mode, some of them can't composite the buttons over the menu background. In VLC settings go to "Video" and look through the "Output" dropdown. If "Automatic" isn't working try one of the DirectX or OpenGL ones. Note that you'll have to close and re-open VLC every time you change that setting to test.
markofwolves
Toad King wrote: Wed Oct 09, 2024 1:33 am It could depend on the video output mode, some of them can't composite the buttons over the menu background. In VLC settings go to "Video" and look through the "Output" dropdown. If "Automatic" isn't working try one of the DirectX or OpenGL ones. Note that you'll have to close and re-open VLC every time you change that setting to test.
OpenGL it works but with some problems. Thanks anyway :wink:
MrPenguin
Post by MrPenguin »
markofwolves wrote: Tue Oct 08, 2024 11:07 pm I have problems with 4k Blu-Rray menu with VLC.
IIRC VLC 3.0.x does not support HDR content, and so it will display "washed out" colors even if you do manage to get the menus working.
