A Nightmare on Elm Street Dump Submitted
Ralph P.
#1 Post by Ralph P. » Sat Oct 05, 2024 3:18 pm
Greetings,
MKB20_v77_A_Nightmare_on_Elm_Street_48B2
Dump Submitted.
keydb_helper
Re: A Nightmare on Elm Street Dump Submitted
#2 Post by keydb_helper » Thu Oct 10, 2024 12:58 am
Greetings,
Dump Submitted.
A new release of A Nightmare on Elm Street authored in August 2024 has been added to the public keydb. It may add support for your disc.
(Disc ID 0xE3B636717A33F66C443D372E06001BA4BE6E94C9)
Public KeyDB Disc Submissions
maczrool
#3 Post by maczrool » Thu Oct 10, 2024 10:37 am
I submitted a dump for this too. Definitely taking a while for this one.
MrPenguin
#4 Post by MrPenguin » Fri Oct 11, 2024 10:53 am
Have you tried downloading the KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
maczrool
#5 Post by maczrool » Fri Oct 11, 2024 11:21 am
Haven't tried that. Will try now and report back. Thanks!
maczrool
#6 Post by maczrool » Fri Oct 11, 2024 11:32 am
Okay. That seemed to work. Ripping now! Does the file need to be the zip version or the decompressed keydb.cfg? I wasn't certain so I put both in the MakeMKV directory.
MrPenguin
#7 Post by MrPenguin » Fri Oct 11, 2024 11:40 am
You only need the uncompressed KEYDB.cfg file. And for MacOS and Linux-based machines, its file name must literally be KEYDB.cfg rather than (say) keydb.cfg because their file systems are case-sensitive.
And I think this proves that KEYDB does contain the key for the 48B2 disk.
maczrool
#8 Post by maczrool » Fri Oct 11, 2024 11:57 am
Thanks for your help! I will go ahead and delete the zip archive then.
ben_uk
#9 Post by ben_uk » Sat Oct 12, 2024 6:22 pm
UK disc does not decrypt. Email sent.
MKB20_v77_A_Nightmare_on_Elm_Street_87E4.tgz
