A Nightmare on Elm Street Dump Submitted
Ralph P.
Post by Ralph P. » Sat Oct 05, 2024 3:18 pm
Greetings,
MKB20_v77_A_Nightmare_on_Elm_Street_48B2
Dump Submitted.
keydb_helper
Re: A Nightmare on Elm Street Dump Submitted
Post by keydb_helper » Thu Oct 10, 2024 12:58 am
Ralph P. wrote: Sat Oct 05, 2024 3:18 pm Greetings,
Dump Submitted.
A new release of A Nightmare on Elm Street authored in August 2024 has been added to the public keydb. It may add support for your disc.
(Disc ID 0xE3B636717A33F66C443D372E06001BA4BE6E94C9)
Public KeyDB Disc Submissions
maczrool
Post by maczrool » Thu Oct 10, 2024 10:37 am
I submitted a dump for this too. Definitely taking a while for this one.
MrPenguin
Post by MrPenguin » Fri Oct 11, 2024 10:53 am
maczrool wrote: Thu Oct 10, 2024 10:37 am I submitted a dump for this too. Definitely taking a while for this one.
Have you tried downloading the KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
maczrool
Post by maczrool » Fri Oct 11, 2024 11:21 am
Haven't tried that. Will try now and report back. Thanks!
maczrool
Post by maczrool » Fri Oct 11, 2024 11:32 am
Okay. That seemed to work. Ripping now! Does the file need to be the zip version or the decompressed keydb.cfg? I wasn't certain so I put both in the MakeMKV directory.
MrPenguin
Post by MrPenguin » Fri Oct 11, 2024 11:40 am
maczrool wrote: Fri Oct 11, 2024 11:32 am Does the file need to be the zip version or the decompressed keydb.cfg? I wasn't certain so I put both in the MakeMKV directory.
You only need the uncompressed KEYDB.cfg file. And for MacOS and Linux-based machines, its file name must literally be KEYDB.cfg rather than (say) keydb.cfg because their file systems are case-sensitive.
And I think this proves that KEYDB does contain the key for the 48B2 disk.
maczrool
Post by maczrool » Fri Oct 11, 2024 11:57 am
Thanks for your help! I will go ahead and delete the zip archive then.
ben_uk
Post by ben_uk » Sat Oct 12, 2024 6:22 pm
UK disc does not decrypt. Email sent.
MKB20_v77_A_Nightmare_on_Elm_Street_87E4.tgz
