Menu problem with Blu-Ray 4K on VLC
markofwolves
#1 Post by markofwolves » Tue Oct 08, 2024 11:07 pm
Hello. I have problems with 4k Blu-Rray menu with VLC. The image appears but not with the buttons. I use Java version 8, update 421 build 1.8.0_421_b09. How can I solve it? Thanks.
Toad King
Re: Menu problem with Blu-Ray 4K on VLC
#2 Post by Toad King » Wed Oct 09, 2024 1:33 am
It could depend on the video output mode, some of them can't composite the buttons over the menu background. In VLC settings go to "Video" and look through the "Output" dropdown. If "Automatic" isn't working try one of the DirectX or OpenGL ones. Note that you'll have to close and re-open VLC every time you change that setting to test.
markofwolves
#3 Post by markofwolves » Thu Oct 10, 2024 10:56 pm
Toad King wrote: Wed Oct 09, 2024 1:33 am It could depend on the video output mode, some of them can't composite the buttons over the menu background. In VLC settings go to "Video" and look through the "Output" dropdown. If "Automatic" isn't working try one of the DirectX or OpenGL ones. Note that you'll have to close and re-open VLC every time you change that setting to test.
OpenGL it works but with some problems. Thanks anyway :wink:
MrPenguin
#4 Post by MrPenguin » Sun Oct 13, 2024 10:24 am
markofwolves wrote: Tue Oct 08, 2024 11:07 pm I have problems with 4k Blu-Rray menu with VLC.
IIRC VLC 3.0.x does not support HDR content, and so it will display "washed out" colors even if you do manage to get the menus working.
