jbrip
Posts: 35 Joined: Wed Aug 28, 2024 12:26 am
Post
by jbrip » Tue Oct 08, 2024 2:37 pm
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v01.0 id=DFE22909F92F)
Saved AACS dump file as C:\Users\x/.MakeMKV/MKB20_v77_Death_Becomes_Her_46A8.tgz
Disc Information
Label: DEATH_BECOMES_HER
Timestamp: 2024-08-13 17:54:00
Protection: AACS2.0/C v77
Data capacity: 75.64 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Posts: 4607 Joined: Wed Jul 22, 2020 11:25 pm
Post
by dcoke22 » Tue Oct 08, 2024 3:45 pm
Hopefully you also emailed the dump to
svq@makemkv.com . Attaching dumps to a post in the forum usually doesn't get them to where they need to go, but emailing them does.
UHD FAQ
jbrip
Post
by jbrip » Tue Oct 08, 2024 6:05 pm
I will go ahead and do that right away. Thanks for the heads up.
rhett7660
Posts: 47 Joined: Wed Apr 06, 2022 6:46 pm
Post
by rhett7660 » Tue Oct 15, 2024 3:51 am
I don't know if it was submitted or not... but I just submitted it.
MrPenguin
Posts: 1967 Joined: Thu Oct 19, 2023 11:31 pm
Post
by MrPenguin » Wed Oct 16, 2024 12:21 pm
jbrip wrote: Tue Oct 08, 2024 2:37 pm
The latest
KEYDB.cfg file contains this entry:
0xDD945E058D930F40D638E8E7E65D4F0A8FC0E2A0 = Death_Becomes_Her [Death Becomes Her] | D | 2024-08-14
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
rhett7660
Post
by rhett7660 » Mon Oct 21, 2024 12:30 am
FYI... this is now up and working! I was able to rip it today.
jbrip
Post
by jbrip » Mon Nov 11, 2024 12:25 am
Yep. I noticed it 3-4 weeks after and it works now. Thanks!
