Just received my 4K replacement disc for Severin Films' 4K UHD of Dario Argento's Opera (1987) & MakeMKV is unable to open this one for me at this moment, so sent the dump file to the necessary place. Cheers!
MKB20_v77_OPERA_UHD_119E
Opera (1987) Severin Films 4K UHD V2 Dump
GasmaskAvenger
Re: Opera (1987) Severin Films 4K UHD V2 Dump
The latest KEYDB.cfg file contains this entry:GasmaskAvenger wrote: Sat Oct 05, 2024 1:26 am Just received my 4K replacement disc for Severin Films' 4K UHD of Dario Argento's Opera (1987) & MakeMKV is unable to open this one for me at this moment, so sent the dump file to the necessary place. Cheers!
0xB48C566C60B244999F41ADAAC9F75886B5BBA2B6 = OPERA_UHD | D | 2024-06-28-
GasmaskAvenger
That's for the original Severin 4K disc and is incompatible with the newly circulating replacement 4K disc they're mailing out.MrPenguin wrote: Sat Oct 05, 2024 3:40 pm The latest KEYDB.cfg file contains this entry:Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?Code: Select all
keydb_helper
The 119E release of Opera with disc ID 0x99BC7E1E04A2CE790F433B2FBF25E86534483A99 has been added to the public keydb. It should work with your particular disc.GasmaskAvenger wrote: Sat Oct 05, 2024 1:26 am Just received my 4K replacement disc for Severin Films' 4K UHD of Dario Argento's Opera (1987) & MakeMKV is unable to open this one for me at this moment, so sent the dump file to the necessary place. Cheers!
Public KeyDB Disc Submissions
GasmaskAvenger
Works perfectly now. Thank you!keydb_helper wrote: Sun Oct 06, 2024 12:40 am The 119E release of Opera with disc ID 0x99BC7E1E04A2CE790F433B2FBF25E86534483A99 has been added to the public keydb. It should work with your particular disc.
