Opera (1987) Severin Films 4K UHD V2 Dump
GasmaskAvenger
Post by GasmaskAvenger »
Just received my 4K replacement disc for Severin Films' 4K UHD of Dario Argento's Opera (1987) & MakeMKV is unable to open this one for me at this moment, so sent the dump file to the necessary place. Cheers!
MKB20_v77_OPERA_UHD_119E
MrPenguin
Re: Opera (1987) Severin Films 4K UHD V2 Dump
Post by MrPenguin »
GasmaskAvenger wrote: Sat Oct 05, 2024 1:26 am Just received my 4K replacement disc for Severin Films' 4K UHD of Dario Argento's Opera (1987) & MakeMKV is unable to open this one for me at this moment, so sent the dump file to the necessary place. Cheers!
The latest KEYDB.cfg file contains this entry:
0xB48C566C60B244999F41ADAAC9F75886B5BBA2B6 = OPERA_UHD | D | 2024-06-28
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
GasmaskAvenger
MrPenguin wrote: Sat Oct 05, 2024 3:40 pm The latest KEYDB.cfg file contains this entry:
That's for the original Severin 4K disc and is incompatible with the newly circulating replacement 4K disc they're mailing out.
keydb_helper
Post by keydb_helper »
The 119E release of Opera with disc ID 0x99BC7E1E04A2CE790F433B2FBF25E86534483A99 has been added to the public keydb. It should work with your particular disc.
Public KeyDB Disc Submissions
GasmaskAvenger
keydb_helper wrote: Sun Oct 06, 2024 12:40 am The 119E release of Opera with disc ID 0x99BC7E1E04A2CE790F433B2FBF25E86534483A99 has been added to the public keydb. It should work with your particular disc.
Works perfectly now. Thank you! :D
