The Martian failed to open disc?
suLLy_718
Post by suLLy_718 » Fri Oct 04, 2024 3:05 pm
Bought 2nd hand, for promotional use only on box. Any ideas bad disc or makemkv need to be restarted?
Saved AACS dump file as C:\Users\pc/.MakeMKV/MKB20_v60_The_Martian_13B3.tgz
Re: The Martian failed to open disc?
Post by Billycar11 » Fri Oct 04, 2024 9:25 pm
MrPenguin
Post by MrPenguin » Fri Oct 04, 2024 11:05 pm
suLLy_718 wrote: Fri Oct 04, 2024 3:05 pm Bought 2nd hand, for promotional use only on box. Any ideas bad disc or makemkv need to be restarted?
The latest KEYDB.cfg file contains this entry:
0x9950652BAB77458DB947EA0808A0B015E5C98F1A = THE MARTIAN (The Martian) | D | 2015-12-01
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
