Plane 2023 - Dump submited
MKB20_v77_Plane_2D42
Re: Plane 2023 - Dump submited
Any news on this or Creed III?
The best way to tell if a hashed key has been made available for your discs is to stick the disc in the player and try to rip it. If a key exists, MakeMKV will download it assuming everything is functioning correctly.
If I could rip them it I wouldn't be posting here.
Check your PM?
keydb_helper
The 2D42 release of Plane with disc ID 0xA619A5C957BDB2C967C6E9AFE4049A0167385104 has been added to the public keydb
Public KeyDB Disc Submissions
Yes it does work now. Thanks
