MakeMKV FLAC Rip
K@mpfH@mster
MakeMKV FLAC Rip
Post by K@mpfH@mster » Thu Aug 01, 2024 11:16 am
Hi, I downloaded the flatpak version of MakeMKV. It works generally but if I select the FLAC preset it stops after several minutes without doing/creating anything. It works with DEFAULT so i guess it has something to do with Flac converting.
Re: MakeMKV FLAC Rip
Post by dcoke22 » Thu Aug 01, 2024 3:04 pm
MakeMKV uses ffmpeg underneath to do audio conversion. On the Windows and Mac versions of MakeMKV, a tiny version of ffmpeg ships with the binary. On Linux, it uses whatever ffmpeg is on the system. There are all kinds of reports of trouble with MakeMKV using ffmpeg 6. This interaction between MakeMKV and ffmpeg is most likely the root cause of the behavior you're seeing.
K@mpfH@mster
Post by K@mpfH@mster » Thu Aug 01, 2024 5:03 pm
But how can I solve this?
hartie95
Post by hartie95 » Sat Aug 31, 2024 9:58 pm
For me locally I fixed it by shipping ffmpeg 4.4.4 with the flatpak, made a pull request for it, which should contain a link to test the change, in case you don't want to wait for a merge:
https://github.com/flathub/com.makemkv.MakeMKV/pull/90
K@mpfH@mster
Post by K@mpfH@mster » Sun Sep 01, 2024 5:34 am
THX, I hope there will be a final FLATPAK soon
K@mpfH@mster
Post by K@mpfH@mster » Sun Sep 08, 2024 11:33 am
Hey, I just recieved a Flatpak update and with this FLAC Rip worked, now I need to find out how to rip rip from disc instead from ISO
Post by mike admin » Mon Sep 30, 2024 1:44 pm
fixed in 1.17.8
K@mpfH@mster
Post by K@mpfH@mster » Mon Sep 30, 2024 3:28 pm
When will it be released?
MrPenguin
Post by MrPenguin » Mon Sep 30, 2024 8:26 pm
It has already been released... :mrgreen:
K@mpfH@mster
Post by K@mpfH@mster » Mon Sep 30, 2024 10:10 pm
But not as FLATPAK
Post by Woodstock » Tue Oct 01, 2024 12:43 am
That would depend on whoever generates the flatpak, which isn't the author...
