Bad Boys Ride or Die Dump Submitted
Spearfish25
#1 Post by Spearfish25 » Tue Sep 24, 2024 8:46 pm
MKB20_v77_Bad_Boys-_Ride_or_Die_5356
MrPenguin
Re: Bad Boys Ride or Die Dump Submitted
#2 Post by MrPenguin » Tue Sep 24, 2024 8:49 pm
Spearfish25 wrote: Tue Sep 24, 2024 8:46 pm MKB20_v77_Bad_Boys-_Ride_or_Die_5356
The latest KEYDB.cfg file contains these entries:
0x3EAD35E54C8528372DBEEBADA45ABCFE876E931B = BAD_BOYS_RIDE_OR_DIE (Bad Boys: Ride or Die - 4K Ultra HD) | D | 2024-07-26
0xCE6A6E1E20299F68EEBE28AB0CC0D6F8DCFEA1A0 = BAD_BOYS_RIDE_OR_DIE (Bad Boys: Ride or Die - 4K Ultra HD) | D | 2024-07-10
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
Spearfish25
#3 Post by Spearfish25 » Tue Sep 24, 2024 9:40 pm
Nope, downloaded the file, copied to the directory and restarted MakeMKV. Failed to open the disc.
Toad King
#4 Post by Toad King » Wed Sep 25, 2024 2:17 am
My steelbook copy ripped and decrypted fine.
BULLBOYKENNELS
#5 Post by BULLBOYKENNELS » Wed Sep 25, 2024 3:28 am
Toad King wrote: Wed Sep 25, 2024 2:17 am My steelbook copy ripped and decrypted fine.
Same for me.
polskasubie
#6 Post by polskasubie » Wed Sep 25, 2024 3:28 am
my copy ripped once i downloaded the latest keydb file
MKB20_v77_Bad_Boys-_Ride_or_Die_15F2
BULLBOYKENNELS
#7 Post by BULLBOYKENNELS » Wed Sep 25, 2024 3:31 am
Spearfish25 wrote: Tue Sep 24, 2024 9:40 pm Nope, downloaded the file, copied to the directory and restarted MakeMKV. Failed to open the disc.
If your on Mac then it's
~/Library/MakeMKV
Windows not sure of it's location
MrPenguin
#8 Post by MrPenguin » Wed Sep 25, 2024 9:54 am
BULLBOYKENNELS wrote: Wed Sep 25, 2024 3:31 am If your on Mac then it's
~/Library/MakeMKV
For Mac and Linux, the file also needs literally to be named KEYDB.cfg rather than keydb.cfg, because their file systems are case-sensitive.
Hopefully, KEYDB will gain some more entries for this title over the next few days. I see there's a third entry now already:
0x5564815CF41A9D645683974232FEEDD919A25F9A = BAD_BOYS_RIDE_OR_DIE (Bad Boys: Ride or Die - 4K Ultra HD) | D | 2024-07-26
InTheZoneAC
#9 Post by InTheZoneAC » Sun Sep 29, 2024 8:45 pm
I'm on windows, where do I manually add these lines or find/add the latest key?
I searched my C drive for keydb.cfg and it found two KEYDB.CFG files, one in appdata\roaming\aacs and another in programdata\aacs. I added the two lines provided in this thread to both files, saved, restarted makemkv and get the same result. The folder (users\my name\.MakeMKV) with the dumps only shows the dumps where the disc failed to open if that matters.
MrPenguin
#10 Post by MrPenguin » Sun Sep 29, 2024 8:57 pm
InTheZoneAC wrote: Sun Sep 29, 2024 8:45 pm I'm on windows, where do I manually add these lines or find/add the latest key?
The KEYDB lines posted to this forum have all of their keys removed deliberately, because I don't think this forum is an appropriate place for such things. You'll need to copy the entire latest KEYDB.cfg file into MakeMKV's data directory (which is where MakeMKV also writes its TGZ dump files) and then restart MakeMKV. And then try decrypting your disk again.
The KEYDB.cfg file is updated frequently, and so old copies on your hard drive are unlikely to contain the entries you need. However, the copy in appdata\roaming\aacs suggests to me that you might also have FindVUK.exe installed. In which case, you could execute
> findvuk synchronize
to bring your local copy up-to-date. And then copy the updated KEYDB.cfg file into MakeMKV's data directory.
Proxima
#11 Post by Proxima » Mon Sep 30, 2024 10:32 am
into which folder must the KEYDB.cfg be copied under Windows? Which folder exactly is the MakeMKV data folder under Windows? There are no .tgz files on my Windows system.
caseablee
#12 Post by caseablee » Mon Sep 30, 2024 5:24 pm
Proxima wrote: Mon Sep 30, 2024 10:32 am Hello,
By default, the MakeMKV folder should be in:
C:\Users\[username]\.MakeMKV
(replace [username] with your local Windows user name)
azbeef
#13 Post by azbeef » Wed Oct 02, 2024 4:04 pm
Sorry for a newbie question as well: I downloaded the latest KEYDB file and placed it in my MakeMKV directory, but how do I extract the exact file for Bad Boys (the one starting with MKB20)? Or do I even need to find that exact file? I'm on a Mac, if that makes a difference.
MrPenguin
#14 Post by MrPenguin » Wed Oct 02, 2024 5:56 pm
azbeef wrote: Wed Oct 02, 2024 4:04 pm Sorry for a newbie question as well: I downloaded the latest KEYDB file and placed it in my MakeMKV directory, but how do I extract the exact file for Bad Boys (the one starting with MKB20)?
You don't extract the MKB20_xxx.tgz file. You just copy the latest KEYDB.cfg into MakeMKV's data directory and then start MakeMKV. Seeing as you are a Mac user, the file must be literally be called KEYDB.cfg and not (say) keydb.cfg, because the MacOS file system is case-sensitive.
The point is that KEYDB.cfg is a alternative public database containing the known BluRay keys which MakeMKV is able to read, should MakeMKV's own private "hashed keys" database not contain your disk.
