Pioneer BDR-X13 Usb
Reveille
Pioneer BDR-X13 Usb
Got this drive to use to rip my UHD drives to use in Meida Server at home and it works great with DVD Fab ripping blu-rays but not recognizing by UHD discs. Do I need to change the firmware.
Re: Pioneer BDR-X13 Usb
Without knowing more about the drive, the answer is, "Donno".
What firmware does it have installed on it? Any firmware date on or after 12/22/2022 is blocked from delivering the drives capabilities to non-approved software, and blocked from accepting other firmware.
Propaganda
Hi guys, let me post mine. Also not able to rip UHD discs with the below mentioned firmware.
Pioneer BD-RW BDR-X13U
Manufacturer: PIONEER
Product: BD-RW BDR-X13U
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-07-26
Drive platform: RS9401
Firmware name: PIONEER BDR-213T
Firmware version: 1.02/ID29
Revision: 1.02
Email me this drive info I have a flasher for itPropaganda wrote: Sat Sep 28, 2024 7:55 pm Hi guys, let me post mine. Also not able to rip UHD discs with the below mentioned firmware.
Revision: 1.02
UHD only works on Pioneer drives with MakeMKV and that is only if the firmware date is prior to December 2022. Any newer and UHD readability doesn't work at all.Reveille wrote: Sat Sep 28, 2024 4:51 pm Got this drive to use to rip my UHD drives to use in Meida Server at home and it works great with DVD Fab ripping blu-rays but not recognizing by UHD discs. Do I need to change the firmware.
Reveille
This is all I can find in Windows Device Manager. I am assuming that 1.04 is likely the firmware so I am probably screwed with UHD on this drive.
Device USBSTOR\CdRom&Ven_PIONEER&Prod_BD-RW___BDR-X13&Rev_1.04\1714062522700103&0 was configured.
MrPenguin
I suspect you are correct, but you could also install MakeMKV and report the contents of its "info" window (ideally with your drive's serial number redacted).Reveille wrote: Sun Sep 29, 2024 5:21 pm This is all I can find in Windows Device Manager. I am assuming that 1.04 is likely the firmware so I am probably screwed with UHD on this drive.
1.02 is the last that works.
GordHomePlex
I have:
Revision: 1.03
Serial number: ----
Firmware date: 2022-12-12
Can this drive still be flashed for ripping UHD videos?
No.Firmware date must be pre December 2022.GordHomePlex wrote: Sun Sep 29, 2024 10:36 pmI have:
Revision: 1.03
Serial number: ----
Reveille
New drive is as follows
Product: BD-RW BDR-212V
Revision: 1.02
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 25
Firmware version: ID06
How do I flash it to use UHD discs?
Thank you
Revision: 1.02
Thank you
Read your PM.Reveille wrote: Tue Oct 15, 2024 1:55 am New drive is as follows
Revision: 1.02
Thank you
Regarding your first post. It will only work for UHDs with Makemkv, XReveal and AnyDVD but not with DVDFab.
Reveille
Thank you very much! I got drive flashed and MakeMKV worked great so think I am going to buy a license for that one to burn my UHD's!
If you still burn: Read this.Reveille wrote: Wed Oct 16, 2024 7:01 pm Thank you very much! I got drive flashed and MakeMKV worked great so think I am going to buy a license for that one to burn my UHD's!
https://forum.cdrinfo.pl/f107/avoid-lay ... -rs-99056/
Ulrich
I also have the drive, here is here is the data
OS device name: F:
Producer: PIONEER
Revision: 1.01
Serial number: XXXXXXXXXXXXX
Firmware date: 2022-02-18
Bus encryption markings: 1B
Highest AACS version: 19
Drive platform: Pioneer RS9400
Firmware version: ID56
If I understand this correctly, LibreDrive must be enabled. How can I activate LibreDrive?
Hopefully someone can give me a hint, thanks.
OS device name: F:
Producer: PIONEER
Revision: 1.01
