Pioneer BDR-X13 Usb
Reveille
Pioneer BDR-X13 Usb
Post by Reveille »
Got this drive to use to rip my UHD drives to use in Meida Server at home and it works great with DVD Fab ripping blu-rays but not recognizing by UHD discs. Do I need to change the firmware.
Re: Pioneer BDR-X13 Usb
Without knowing more about the drive, the answer is, "Donno".
What firmware does it have installed on it? Any firmware date on or after 12/22/2022 is blocked from delivering the drives capabilities to non-approved software, and blocked from accepting other firmware.
Propaganda
Post by Propaganda »
Hi guys, let me post mine. Also not able to rip UHD discs with the below mentioned firmware.
Pioneer BD-RW BDR-X13U
Manufacturer: PIONEER
Product: BD-RW BDR-X13U
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-07-26
Drive platform: RS9401
Firmware name: PIONEER BDR-213T
Firmware version: 1.02/ID29
Propaganda wrote: Sat Sep 28, 2024 7:55 pm Hi guys, let me post mine. Also not able to rip UHD discs with the below mentioned firmware.
Revision: 1.02
Email me this drive info I have a flasher for it
Reveille wrote: Sat Sep 28, 2024 4:51 pm Got this drive to use to rip my UHD drives to use in Meida Server at home and it works great with DVD Fab ripping blu-rays but not recognizing by UHD discs. Do I need to change the firmware.
UHD only works on Pioneer drives with MakeMKV and that is only if the firmware date is prior to December 2022. Any newer and UHD readability doesn't work at all.
Reveille
Post by Reveille »
This is all I can find in Windows Device Manager. I am assuming that 1.04 is likely the firmware so I am probably screwed with UHD on this drive.
Device USBSTOR\CdRom&Ven_PIONEER&Prod_BD-RW___BDR-X13&Rev_1.04\1714062522700103&0 was configured.
MrPenguin
Post by MrPenguin »
Reveille wrote: Sun Sep 29, 2024 5:21 pm This is all I can find in Windows Device Manager. I am assuming that 1.04 is likely the firmware so I am probably screwed with UHD on this drive.
I suspect you are correct, but you could also install MakeMKV and report the contents of its "info" window (ideally with your drive's serial number redacted).
1.02 is the last that works.
GordHomePlex
Post by GordHomePlex »
Coopervid wrote: Sun Sep 29, 2024 6:52 pm 1.03 is the last that works.
I have:
Revision: 1.03
Serial number: ----
Firmware date: 2022-12-12
Can this drive still be flashed for ripping UHD videos?
GordHomePlex wrote: Sun Sep 29, 2024 10:36 pm
I have:
Revision: 1.03
Serial number: ----
No.Firmware date must be pre December 2022.
Reveille
Post by Reveille »
New drive is as follows
Product: BD-RW BDR-212V
Revision: 1.02
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 25
Firmware version: ID06
How do I flash it to use UHD discs?
Thank you
Reveille wrote: Tue Oct 15, 2024 1:55 am New drive is as follows
Revision: 1.02
Thank you
Read your PM.
Regarding your first post. It will only work for UHDs with Makemkv, XReveal and AnyDVD but not with DVDFab.
Reveille
Post by Reveille »
Thank you very much! I got drive flashed and MakeMKV worked great so think I am going to buy a license for that one to burn my UHD's!
Reveille wrote: Wed Oct 16, 2024 7:01 pm Thank you very much! I got drive flashed and MakeMKV worked great so think I am going to buy a license for that one to burn my UHD's!
If you still burn: Read this.
https://forum.cdrinfo.pl/f107/avoid-lay ... -rs-99056/
Ulrich
Post by Ulrich »
I also have the drive, here is here is the data
OS device name: F:
Producer: PIONEER
Revision: 1.01
Serial number: XXXXXXXXXXXXX
Firmware date: 2022-02-18
Bus encryption markings: 1B
Highest AACS version: 19
Drive platform: Pioneer RS9400
Firmware version: ID56
If I understand this correctly, LibreDrive must be enabled. How can I activate LibreDrive?
Hopefully someone can give me a hint, thanks.
